Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Like Tree1Likes
  • 1 Post By PeteH
Old 09-15-2017, 05:14 AM
Default lucas wiper cable
Anyone else ever experience when turning on the windshield wipers the spiral cable begins to buckle or bind and the arms stop moving? Mine is doing this between the first wiper and the motor. Any suggestions.
Old 09-15-2017, 05:33 AM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
The spiral cable has to ride in a steel tube over its entire length, and be lubricated with lithium grease inside the tube. The tube should be shaped so any bends are smooth and gradual.
Chris
Old 09-15-2017, 11:54 AM
Cobra Make, Engine: FF 289Comp #8955
If you need to make a tube, buy some copper nickel brake line, 3/8" I think, it flares well, and bends easy.
1985 CCX likes this.
Old 09-15-2017, 02:00 PM
I knew you were going to say that. Now I know the piece that got thrown away. It was 3/8" line with a Ferrulel nut on the end about 8" long and another long piece.....DAMN. Now have to pull the whole dash out......
Old 09-16-2017, 09:46 PM
spf645's Avatar
Cobra Make, Engine: Superformance, 351w
Also make sure the spiral cable makes good contact with the gear on the shaft that goes up to the wiper arm. Mine would skip on the gear at times. Wasn't a fun fix.. Working upside down, backwards, and in the blind. Taking the seat out did make it a little easier. Taking the dash completely out might just be the best way.
Tags
lucas wiper
HTML code is On
