Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Like Tree1Likes
  • 1 Post By patrickt
Old 05-26-2020, 05:10 PM
Cobra Make, Engine: Kirkham 289FIA, roller
Default Aluminum Coolant Pipe Sources
I'm soon to be needing some sections of coolant tubes to connect between the radiator and engine. I see a lot of Cobra engine photos with what look to be custom pieces with bends, etc. Ideally, I would be able to get a few pieces so I would just need some short rubber/silicone connectors. I'm thinking of aluminum to avoid introducing stainless steel into the cast iron/aluminum mix.
Your suggestions on a good source would be most appreciated!
Mark
Old 05-26-2020, 06:36 PM
Summit Racing has the aluminum tubes and the rubber sleeve adapters and couplings. Just search for coolant tubes and hose couplers/sleeves.
Dwight likes this.
Old 05-26-2020, 07:11 PM
Ivygreen65's Avatar
You might look at Speedway Motors
https://www.speedwaymotors.com/shop/...14-4-585-30521
https://www.speedwaymotors.com/shop/...14-4-585-10068
Old 05-26-2020, 11:35 PM
xb-60's Avatar
Originally Posted by MarkAZ View Post
....I'm thinking of aluminum to avoid introducing stainless steel into the cast iron/aluminum mix.....
Mark, if you use stainless tubing, so long as there's no 'mechanical' connection to cast iron or the aluminium castings, there's no problem.
Glen
HTML code is On
