Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Like Tree1Likes
  • 1 Post By patrickt
Old 05-26-2020, 05:10 PM
Cobra Make, Engine: Kirkham 289FIA, roller
Default Aluminum Coolant Pipe Sources
I'm soon to be needing some sections of coolant tubes to connect between the radiator and engine. I see a lot of Cobra engine photos with what look to be custom pieces with bends, etc. Ideally, I would be able to get a few pieces so I would just need some short rubber/silicone connectors. I'm thinking of aluminum to avoid introducing stainless steel into the cast iron/aluminum mix.
Your suggestions on a good source would be most appreciated!
Mark
HTML code is On
