Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 04-27-2021, 09:30 AM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Supplier: DB Electrical, Alternators,Starters etc
Thought I would share my positive experience here using an Amazon supplier I found called DB Electrical. I purchased a Ford type (Fox body Mustang) New 150A Alternator not rebuilt with no core charge, from them via Amazon and was happy to learn their plant is in Kingsport TN. If you're shopping for starters and Alternators check these folks out. Ive got only 800 miles on the alt but very stable voltage output and feeds my 100A+ demand electrical system without a complaint. It comes with a alt test report with rpm vs current graph. My Alt was nearly 50% less buying here compared to Advance or AutoZone last year including delivery to the house. I noticed prices are up a little in 2021 but still very good.
https://www.dbelectrical.com/
"...some assembly required, ages 8 and up...... well that took longer than expected......
HTML code is On
