Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Like Tree1Likes
  • 1 Post By patrickt
Old 05-01-2023, 08:41 PM
Cobra Make, Engine: Hi-Tech Street Roadster
Default Smiths Mechanical Coolant Temp Gauge
Recently worked through some overheating issues (electric fan switch was disabled). I now have an issue with the coolant temp gauge (Smiths mechanical unit) showing NO temp reading. Sensor in expansion tank previously worked fine up until overheating issues. After system has been bled of all air, still no temp reading. Any suggestions and thanks in advance.
Old 05-02-2023, 05:21 AM
It's likely that the gauge is kaput. A defining test would be to immersing the gauge bulb in boiling water. It's time to replace, or it might be able to be repaired by Nisonger. Probably not worth the effort though.
Old 05-02-2023, 06:51 AM
HealeyRick's Avatar
Nisonger is no longer in the repair business after a flood in their shop. They still sell new units.
Rick
My SBF Austin-Healey build:
http://forum.britishv8.org/read.php?13,8264
Old 05-02-2023, 07:29 AM
One has to ask, did they know the temperature of the water?
CJ428CJ likes this.
Old 05-02-2023, 04:39 PM
Thanks for the feedback all, new gauge on order based on Nisonger's feedback as well.
Old 05-06-2023, 01:17 PM
you should verify the gauge,good luck.
HTML code is On
