Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 05-02-2002, 06:59 PM
Cobra Make, Engine: ERA Cobra #273, 427 S/O, ERA GT-40 #2057, Excalibur Cobra.
Question Adding Instruments
I'M INSTALLING A KENNE-BELL BLOWER IN MY EXCALIBUR COBRA. I PLAN ON INSTALLING A VDO BOOST GAUGE (MY OTHER GAUGES ARE VDO).
THE INSTRUMENT PANEL IS BEAUTIFULLY FINISHED IN A LIGHTLY "PADDED" LEATHER - VERY NICELY DONE AND I DON'T WANT TO "SCREW IT UP".
WHAT IS THE BEST ADVICE ON CUTTING THE HOLE FOR THE GAUGE WITHOUT RUINING THE PADDED LEATHER COVER???
THANKS, AND, Y'ALL HAVE A REALLY GREAT DAY.
BLACKJACK
It's impossible to make anything FOOLPROOF - - Because FOOLS are so ingenious.
Old 05-02-2002, 07:28 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
When I added a gauge to my car, I found the best way was to mark the gauge location with a soap stick (like tailors use), then to cut the leather with a flat, very hot and thin palette knife. It will sear the leather and the padding instantly (no rips or imprecise cuts) and then you can remove the circle of leather you cut and use a very sharp metal punch on the dash, which will leave a straight, clean edge. Install the new gauge, voila. I dont know if your tool selection is broad enough, but a second option is a die cutting wheel. You drill a small pilot hole centered where you want the gauge, assemble the cutter and screw it together. It will cut anything, and leave a perfect hole. A machine shop will have them, and maybe you can rent or borrow it...there are quite expensive to purchase. My set for work ran about $900. You can purchase a similar kit from Northern, but it is a flat punch set. I have a set of these for the house, and they are very nice..about $100 if I remember.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 05-02-2002, 07:32 PM
Cobra Make, Engine: ERA / nascar side oiler
I will take a stab at it ... This is just a guess , so you find a spot with nothing behind it , Measure exactly mark with a center punch . draw a perfect circle . cut the leather with an x cut (twice ) so you can pull back the leather larger than the hole saw , but not larger than the besel . drill pilot hole , then drill with a hole saw in reverse so the teeth don't grab the glass or metal .
Old 05-02-2002, 09:31 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb Best way would be...
To make a template out of thin panel wood, with the exact size hole you want, then just carefully cut around with an exacto knife. Hold the template in place with 100 MPH tape (get it at a military surplus store)
As far as what's behind the leather, sounds like you will need a jigsaw, with the right type of blade. Keep the template in place, until the cuttin's done, or...
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 05-04-2002, 05:10 AM
HEY GUYS,
THANKS VERY MUCH FOR THE GREAT ADVICE. THE BLOWER & INSTRUMENTS ARE GOING INTO THE "EXCALIBUR" AND IT'S FINISHED AND DETAILED SO WELL I'M REALLY CAUTIOUS ABOUT "SCREWING IT UP".
THANKS AGAIN,
Y'ALL HAVE A REALLY GREAT DAY,
BLACKJACK
Old 01-25-2003, 06:39 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Take it to an upolsterer,they will do it right!
Old 01-29-2003, 02:52 PM
KobraKarl's Avatar
Blackjack,
A freind of mine has an orriginal 289 w/ a blower and the boost guage is actually mounted under the dash in a chrome gauge mount like you would find in an auto parts store.
If you want to mount it in your dash , use a 2" hole saw, $15,20 for a decent one (sharp) start the pilot slooow, you do not want the circle cutter to make abrupt contact with your dash when the pilot breaks thruogh the panel! You may want to drill the pilot first. then gently start the cutter at low rpm and youll be done in 30 seconds. If you are really worried cut the leather away first, but i think the margin for error is larger cutting by hand.
good luck, glad you finally got your car
Foolish consistancy is the hobgoblin of tiny minds
Old 01-29-2003, 03:08 PM
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Mark the spot where you plan on installing the new instrument.
Next, place the dynamite .................
Old 01-29-2003, 08:10 PM
CASALEENIE - - - -
I KNOW THE SPOT - - BEND OVER AND I'LL PLACE THE DYNAMITE !!
BLACKJACK
Old 01-29-2003, 09:28 PM
KobraKarl's Avatar
woops.............
just re read the posts and realized ive mixed up the black guys.................. so to speak...........
HTML code is On
