Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
December 2025
Old 06-16-2003, 05:04 PM
Default 275 60 BFG`s
hi
It may seem stupid to ask but how tall 27 or 28" is a 275 60 15 goodrich?
thanks
Old 06-16-2003, 05:28 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
The O.D. is 27.5 inches according to the specs I've seen.
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 06-16-2003, 05:41 PM
jwoodard's Avatar
Cool The tire calculator at SmokeMUP.com..
says they are 27.99".
Jim Woodard
Old 06-16-2003, 05:51 PM
392cobra's Avatar
6th Generation Texan
My BFG Charts says:
Rim width range - 7.0 - 11.00
Overall diameter - 28.0
Tread width - 8.9
Section width on measuring rim width** - 11" on 8" rim
** Section width varies approximately 0.2" for every 0.5"
change in rim width
Old 06-16-2003, 06:12 PM
Thanks guys....
Old 06-17-2003, 04:38 PM
Mr.Fixit's Avatar
(275 mm wide x 60% aspect ratio) x 2 = 12.99" + 15" for rim = 28"
Old 07-05-2003, 08:35 AM
Cobra Make, Engine: Classic Roadster with 427 center oiler
My calculations:
275 X .6 = 165 millimeters is side wall height (aspect ratio is the relationship between the tread width and the side wall height)
Multiply millimeters by .039 to get inches : .039 X 165 = 6.435 inches. Multiply by 2 to get both side wall heights (top and bottom of tire): 6.435 X 2 = 12.87
Add this to the 15" wheel diameter: 15 + 12.87 = 27.87 inches
Paul
life is short: eat dessert first !
Old 07-05-2003, 08:41 AM
luke-44's Avatar
I was just looking this up yesterday - take a look at the attached chart from the Tire Rack....
http://www.tirerack.com/tires/Spec.j...l=Radial+T%2FA
Old 07-07-2003, 05:58 AM
Default they actually measure 27.125
inflated and mounted on steel rims...they are for sale (new) under for sale items
69 Mach 1,428SCJ trak pak,4 speed, 3:91 axle restored
Old 07-26-2003, 09:59 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
27 1/8 th.. someone has been doing burnouts
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 07-26-2003, 10:15 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
The rolling circumference is 84.5 inches on my SPF with 20 PSI air pressure.
Bob
HTML code is On
