View Poll Results: How should I set up my 1965 Mustang Fastback to run in road racing? I want to make Hp
351 windsor bored/stroked to 408ci, 13:1 compression. 1 16.67%
5.0 liter fuel injection. 0 0%
stock 289 hi-po. 0 0%
302 Mexican. 1 16.67%
302 bored/stroked to 347. 2 33.33%
306 with 13:1 compression 2 33.33%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old 12-06-2003, 02:06 PM
Cobra Make, Engine: 1965 Shelby GT350
Default Please help.
Hello guys.
I need to know a few things about a 351W. I am building a 1965 Mustang fastback that I am hoping to set up to run in the vintage road race, so here goes.
1.) is it safe to bore/stroke the stock 351W block to 408ci?
2.) Would it be safe to run 13:1 compression?
3.) My aftermarket parts include Trick Flow Twisted Wedge heads, Trick Flow Pistons, a Comp Cams bumpstick, Melling high Volume oil Pump, Moroso baffled oil pan, Comp lifters and a Edelbrock Victor Jr. manifold. What roller rockers are recommended for this setup? Should I use 1.7:1 or 1.6: rockers? The engine should put out about 750hp.
4.) What suspension components should I include?
5.) Will a toploader 4 speed hanle the stresses of road racing, or should I upgrade to a tremec?
6.) What 9" rearend will fit under the 1965 Mustang Fastback with minimal mods?
Old 12-06-2003, 02:46 PM
Ron61's Avatar
Post
J21,
Yes, it is safe to bore and stroke a 351 Windsor to 408. Mine is 416 and 11:1 compression. Many on the club have them bored and stroked to everything up to 427 but I would stay short of that as you are really pushing the edge there. Just make sure the block is good to start with.
As for the rest, my enjine only puts out around 515-530horse, but I have a friend with oine stroked to 410 and his puts out over 600 horse. I am pretty sure that we both have 1.6 roller rockers. I am using the aluminimun trick flow twisted heads but with a single plane intake manifold and it has all been ported and polished. I kept my power down because I drive the car a lot and it is overpowered for what I do now anyway. The top loader 4 speed could probably be improved on by having it gone through and beefier gears and such put in if you are going to make this an all out race car, which I am guessing from the engine. The suspension and rear end I will leave to the guys with Mustangs. I have a 69 Ford Torino Cobra with a big block that isn't streetable and I think that rear end is wider than the Mustang but can't say for sure. Be sure to get the 31 spline one as that only came on the high performance cars and most of the 9" rear ends were 28 spline. Pete Acala AKA Petec would be a good person to talk to as he just finished his 65 stang and sent me some pictures of him running at Sears Point. So he could tell you what all he used.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 12-06-2003, 07:04 PM
Tony Radford's Avatar
I would talk to Keith Craft about getting that kind of power out of a Windsor SB.
