Old 08-29-2007, 02:59 AM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Question Performance Calculator
Is there a web site available that will calculate performance based on car specs?
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 08-29-2007, 03:06 PM
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
The only item I am aware of is the desktop dyno software.
Old 08-30-2007, 08:35 PM
eschaider's Avatar
Not that I know of but, there is a fine modeling tool from Patrick Hale called Quarter Pro that will and do it in spades. check out the website => http://quarterjr.com/about.htm
Ed
Old 09-01-2007, 02:43 AM
427SnakeSC's Avatar
Thumbs up
Thanks guys! I found a pretty simple one at http://www.letstorquebhp.com/calculator.asp I doesn't take into account tires or gearing, but kinda gives you an idea. Michael at Second Strike claims to have a pretty accurate one, but you have to belong to some registry before he will do your car. Thanks again.
Old 09-01-2007, 03:05 AM
DrC DrC is offline
Cobra Make, Engine: ERA 711 390 FE w/ TKO 600
If you want to get away from the web and get some pretty accurate info try G-Tech. Dash mounted, cigarette lighter power this will give you good data of your car's performance if speed and HP are what your looking for.
Old 09-01-2007, 03:40 AM
427SnakeSC's Avatar
Thanks DrC. Is there a way to use the G-Tech, if you don't have a cigarette lighter?
Old 09-01-2007, 04:43 AM
DrC DrC is offline
I had a lighter installed for radar, garmin, g-tech etc. I wouldn't be able to say for sure. If I can located the manual I'll get back to you.
Rich
Old 09-01-2007, 07:40 AM
Dwight's Avatar
Smile accessory plug
You can buy an accessory plug for $8 to $12 at the parts store and they are easy to install in a Cobra. One #12 wire to ground and one from the fuse panel. I mounted mine just under the dash. I use it for DVD player, cell phone charger and stuff like that.
Dwight
Old 09-01-2007, 11:04 AM
ROUSHAC's Avatar
Try this:
http://www.wallaceracing.com/Calculators.htm
Interesting to see the differences in results calculated using the same data in different calculators.
Dave
Old 09-04-2007, 06:11 AM
427SnakeSC's Avatar
Thanks Roushac, excellent website!
Old 09-04-2007, 07:19 AM
greg schroeder's Avatar
This calculator is for correction to sea level after you have actual 1/4 mile, speed and weather data.
http://www.modulardepot.com/density.php
For one methed of testing I use the G-tech type with computer acquisition software. It's real nice to be able to see any speed to any speed, distance, Gs, and stuff while having the option to put up to 4 cars on one graph. It's important to follow the directions of the unit to ensure valid runs.
