Old 06-25-2008, 05:59 AM
Chaplain's Avatar
Cobra Make, Engine: Everett-Morrison, 429CI
Default Welding on a 9" Differential
I did a search and couldn't find anything. My question is, is there any special procedure for welding on a differential that is off the car? It seems I read or saw one time that it is possible for an arc to jump inside of an assembly, doing damage to a bearing or gear mating surface etc. I want to weld on the brake line tabs and was wondering if I need to dis-assemble the entire rear end first.
Thank you in advance for any advice.
Old 06-25-2008, 06:01 AM
Clois Harlan's Avatar
I have seen it done both ways. Mine was welded without disassembly and that was two years ago and I have not had any issues with the rear end housing or bearings.
Clois
"Let's roll"
"Be part of Something Good
Old 06-25-2008, 06:06 AM
Silverback51's Avatar
Just make sure you have a real good attach point for your ground and you will be fine.
Old 06-25-2008, 06:54 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Grind a spot for the ground before you weld or the arc will find it's path of least resistance.
Old 06-25-2008, 07:01 AM
Roush #1's Avatar
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Chaplain,
All the previous comments are good ones.
One thing that hasn't been mentioned is not to weld too much at one time. Allow the metal to cool to avoid twisting the axle housing.
Jody
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
Old 06-25-2008, 07:08 AM
Cobra Make, Engine: Shell Valley, 514 SVO ... now a 4.6L with an AOD!
If you are welding on the housing, attach your ground to the housing - NOT the axle flange. I've seen a lot of guys attach the ground to the axle flange because it is an easy spot to get to but doing this will ruin your bearings.
I also very much agree on going slow and allow the metal to cool to avoid warping the housing.
Just my $0.02
Dana
