Old 10-20-2008, 09:19 AM
Cobra Make, Engine: Midstates, 501
Default Fluid help Clutch/Rear End
Guys,
Any recommendations on Fluid for a Jag Rear end and Hydralic Clutch?
I am finally putting her back together this weekend, and trying to get all I need lined up.
Old 10-20-2008, 12:15 PM
bump to the top
Old 10-20-2008, 12:24 PM
90 weight, I believe, and don't forget the additive for your limited slip.
Old 10-20-2008, 02:02 PM
Default Good dot 3 brake fluid for the clutch
mjmacqua As Pat said a good 90W for the rearend. Some fluids already have the Posi additive for the rear in the fluid. It should say on the bottle. After you get the car together go to a parking lot and do figure 8's to get the clutches fully wet and the additive on the discs. this is at slow speed. To check of the posi is working OK, wet the rear tires and do a quick burn out. Both tires should be spinning evenly. For the Hydro clutch, use a good DOT 3 fluid for this. Make sure you push in the slave cylinder a couple of time when you bleed the system to remove all the air for a good pedal. Good Luck Rick L.
Old 10-20-2008, 02:48 PM
Default Thanks
Thanks Guys.
Cant wait till this thing is together.
