Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 10-23-2008, 12:54 PM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Ford Front Wheel Studs- Too Short !
Does anyone have a good source for Ford Front Disc wheel studs that are longer than the OEM studs. I need studs longer than the OEM so the lug nuts have enough thread engagement. My Discs are from a Lincoln which must have used a stamped steel wheel, not an alum. alloy. Thanks for any info.
"...some assembly required, ages 8 and up...... well that took longer than expected......
Old 10-23-2008, 01:15 PM
Rick Parker's Avatar
Go to NAPA or a similar full service Auto Parts store. They will have studs available from Dorman or another similar vendor that are utilized on another application.
Rick
Old 10-27-2008, 09:37 AM
kitcarbp's Avatar
Default wheel studs
Thanks Rick I downloaded the Dorman catalog and you were right, they have a massive selection of wheel studs, I will just press one of mine out of the disc and head down to NAPA.
HTML code is On
