Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
December 2025
Old 04-30-2009, 09:25 AM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default How to Measure and Estimate Exhaust System Backpressure
FYI-
I ran across this ref. on exhaust system applications.
While its written by Caterpillar and focuses on turbo-diesel engines (oooh.... that hurt to type), it offers a good explanation on how to set up backpressure measurements on your exhaust system. There is also an equation that is simple to follow to allow you to estimate (A to B comparisons) exhaust system backpressure if you have muffler pressure drop data, gas flow rate (cfm) for your engine,and exhaust gas density at the measured AFR (lets say AFR of 12.5-13.0:1 @ WOT peak power).
See pages 21-25 for the details at the linked document below.
http://www.gregorypoole.com/products...%20SYSTEMS.pdf
"...some assembly required, ages 8 and up...... well that took longer than expected......
Old 04-30-2009, 12:57 PM
DocDirk's Avatar
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Exclamation That made my head hurt!
LOL Bill, that's too much for me, you must have a calculator built into your brain....I love math .... PM me your email address and I'll send you something mathematical for fun.
Regards!!
Dirk
The government giveth and the government taketh away..... if our rights are not God given then they're subject to revision!
Old 08-25-2009, 09:01 PM
Well, I can't say that I grasp everything in that article, but I believe the following:
1/ They seem to be talking about exhaust restrictions, such as small dia tubing and sharp bends, ...basically screw-ups in aftermarket, or muffler shop fabrication.
2/ Backpressure is a much touted term for muffler shops to use when trying to convince customers to put the proper mufflr on their car vs the el-cheapo alternatives. "You'll burn your exhaust valves with no back-pressure" they say. I doubt this very much.
3/ An engine can be thought of as an air pump. Anything you can do to reduce restrictions to both the intake and exhaust is good. Not as critical in 4-strokes, 2-strokes (i.e. MX motorbikes) can use this to great advantage, but hence the narrower power band compared to a 4-stroke because you can't tune a fixed exhaust for a wide range of rpms.
Anyway, I wouldn't worry about back-pressure on your Cobra, especially if you stick to your manufacturers recommendations for an exhaust system.
Old 08-26-2009, 03:03 AM
CHANMADD's Avatar
Primary tubes and length make a difference to the backpressure and hence the power and sound. The collector kind of creates a ventury to speed things up and accelerate the gases. A petrol/gas engine needs to scavenge the exhaust gases as completely and quickly as possible........no backpressure being best in a 4 stroke.
HTML code is On
