Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Old 06-19-2009, 11:49 AM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Question Hydraulic brake light switch
I had my Hobbs brake switch blow a seal & leak fluid under pressure all over my left foot. Thanks for dual master cylinders, still had front brakes so I could drive it home, although somewhat carefully.
The only replacement switch I could locate in a hurry requires 60lbs.pressure to activate.
I would like to find one that comes in @ 2-3lbs & has a 1/8 npt. fitting, normally open, 2- wire connection.
What is everyone else using.
Thanks in advance for any help
Craig
Old 06-19-2009, 12:11 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
I don't have the number handy; but the application is 1965 Mustang. 1/8" NPT & 2 bullet type connectors. Very low pressure required.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
HTML code is On
