02-21-2011, 06:43 PM
Need Assistance with Cobra purchase - Newbee here
Hello, I am new to the forum and looking for assistance in the purchase of my 1st Cobra. I am by no means a mechanical person but have been looking for a year now. Any thing that doesn't seem right then please let me know.
Here is what I have been told about the car:
1998 Lonestar
'69 351 windsor bored 30 over 500 miles on it since the rebuild
650 Holley
560 lift cam
202 heads
disc brakes 355 rear
rack and pinion
paint is good
I do know the speedometer cable isn't hooked up. He told me the plug is straight but this setup requires a 90 degree angle in order to plug it in. I think for $19k the price seems good for my first cobra.
Thanks for any help you can give me.
Reason: Hit enter on accident and wasnt done typing.
02-21-2011, 08:00 PM
Cobra Make, Engine: LS427, Keith Craft 408, TKO-600, 370 Rear-End
Aedds,
The price is good you could part the car out and probably make money check the LoneStar website and see what you get for $20,000 in a basic kit and you will see.
"Live like you are dying”
:Tim McGraw
“Not a worry in the world a cold beer in my hand life is good today, life is good today”
02-22-2011, 06:59 AM
So you are saying it's possibly a good deal and the price is good. Any known problems with the '98 Lonestar?
02-22-2011, 07:53 AM
tx
Cobra Make, Engine: Lonestar Classics
There are no problems with a 98 Lonestar. There have been changes to the car since then but it is still a very solid and reliable cobra. If you buy the car, you may ultimately want to change the Alden shocks to the QA1's and upgrade to the adjustable upper control arms. Easy upgrades.
$19k sounds like a super deal assuming the motor, drivetrain are in good condition. Have a mechanic check it out for you.
Call Brian at LoneStar if you want to know what has changed since 1998.
2009 Lonestar Classics - 351 W
02-22-2011, 10:40 AM
Ca.
You couldent build that car for the $19k hes asking.......
buy it. drive it for a season and then change what you dont
like about it or sell it for the $19k you paid for it...
02-22-2011, 12:14 PM
6th Generation Texan
John Ross has one of the early Lone Stars, #89 in the series.
It has only gotten better with age.
02-22-2011, 01:23 PM
MN
Cobra Make, Engine: B&B, FR302
That's a steal if the drive-train is in good condition. Even if you had to rebuild the engine, trans and rear end you would still be easily valued around 30k. There are a couple Lone Stars around here and (my 2-cents) I've often thought they looked like a real decent car compared to some others.
Roger
02-22-2011, 01:54 PM
Ok, I am ordering the inspection and appraisal to make sure everything is good. Hopefully this one will work out. Does anyone know how to find a speed cable that has a 90 degree bend at the plug in?
02-22-2011, 02:25 PM
Please inform us of the tranny type (brand and model) and any under-car clearance problems with the clutch throwout fork.
Have you thought of sending a Lonestar owner over to check out the car? Nothing escapes someone who has built one.
Best,
Paul
02-22-2011, 02:48 PM
I thought about that but the car is about 2 1/2 hours from me. Once I get things more nailed down then I might call on your expert opinions to help look at the build  When I find out the trany type I will let everyone know but I am not sure what a clutch throwout fork is??
02-22-2011, 06:35 PM
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
Where are you? Do you know about the Texas Cobra Meet coming up in San Marcos at the end of March? http://www.clubcobra.com/forums/show...90#post1102390
Steve
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
02-23-2011, 10:20 AM
So at this point it's a 4 speed top loader but don't know the year or type yet. He said its from a much older car and is getting the number from the tranny later. He is sending me the series # also.
02-23-2011, 02:06 PM
Tx
Cobra Make, Engine: # 238 lonestar w/IRS rear end
If it checks out and looks good you might want to pick it up before someone else comes along and does. From what Brian told me really the only things that changed are the door hangers, shocks, and updated the suspension some.
Eric
Life starts when the little needle goes past 6,500 rpm's
02-26-2011, 08:03 AM
Does anyone think the speed cable is an issue. Would there be a serious reason that would require a 90 degree cable? Also does anyone have a pic of what I am looking at for the clutch throwout fork?
02-26-2011, 08:41 AM
Most all of the Cobra's speedo guages have a 90 degree adapter because of the supports and room behind the guage in the dash. I had to put one on every Cobra I have had. Cobra Restorers in Kennesaw, Ga sells them.
Part number: F-407010 Adapter flexshaft-right angle $ 99.95 plus shipping.
If you have any questions about Lone Stars contact John Ross as suggested above as he is an expert and he has an awesome car...
CAV GT40
02-28-2011, 08:43 AM
Is it difficult to connect the cable? Do you take off the dash or remove anything mechanical? Just trying to understand it since I am not a mechanical person and would need my mechanic to do it.
02-28-2011, 06:57 PM
Fl
Cobra Make, Engine: Antique&Collectible 392 stroked
With any luck at all your mechanic should be able to lay on his back move his right arm this way then that way dislocate his left shoulder and bring his left hand up and under the dash then turn his head as seen in the exorcists to see behind the dash..yea shouldn't be a problem at all
pops67
02-28-2011, 07:08 PM
Ok, got your point.... no problem
03-01-2011, 07:03 AM
http://www.bwanasnake.com/Gary/Build...adster.html#17
This is what the back of the dash will or should look like.
:Tim McGraw
03-06-2011, 02:50 PM
Thanks for everyones assistance on this one but I am going to keep looking around. There is another one closer that I am checking out this week.
