Old 08-31-2011, 02:58 PM
tomh440's Avatar
Just curious, did you ever try to lower the rear float? When they say loosen the float spring I take that to say they lowered the float level.
Tom
Old 08-31-2011, 04:44 PM
Cobra Make, Engine: FFR MKIII 347ci stroker 450hp
Tom
Yes I think I said in my last post that they had me lower the float by 1/2 turn. And when they had the carbuerator back in their shop for inspection they said that they found that the float spring was a little to tight from the new float they had sent me, so they loosened it some.
Old 09-01-2011, 02:12 AM
Gaz64's Avatar
Like all the other advice you have received, I'll reiterate the fact that jet extensions on the secondary are for fuel starvation on acceleration.
Unless your float level is too high, they have little to do with sloshing into the venturi on deceleration.
High float level and long tubes may work, but the main well would get uncovered, then a stall condition of lean return to idle may exist.
You should have bowl vent whistles fitted to both bowls, jet extensions on the secondary with a notched float, and the float levels just under the sight plug.
Old 09-01-2011, 12:35 PM
Thanks for your feedback on this issue. As I'm sure you can tell I didn't graduate summa cum laude in carburetor tuning If you notice from the photos I linked I have bowl vent whistles installed. The folks at AED specialize in performance tuning carburetors so I've been trying to take their advice on this. They told me that they've had folks put on rear jet extenders when they've had a problem like mine and it's fixed the problem??
I did notice yesterday when I started the car it didn't want to idle very well until the motor warmed up some. Maybe to lean
Anyway I appreciate your feedback on this. I'm probably going to try and richen it up just a little to smooth out the cold idle.
Wayne E
Old 09-01-2011, 02:15 PM
Barnsnake's Avatar
It's a hotrod with a carburetor. If you adjust it to idle well when cold it is very unlikely that it will idle properly when warm.
Old 09-01-2011, 03:17 PM
Cobra Make, Engine: 427
I was under the impression that this condition stalling under very sudden hard breaking can be caused by the vacuum draw from the power assisted brakes?
And that's why they sell additional vacuum canisters to be applied to large camed motors?
Old 09-01-2011, 04:17 PM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
You might try simply extending the height of the rear vent with a piece of fuel hose.
-Greg
I've spent most of my money on cars and women. The rest I wasted.
