Old 04-11-2017, 04:38 PM
Axel 427's Avatar
Cobra Make, Engine: Backdraft Racing, Roush 427
Default Lsd
Lookin for a used E36 lsd rear differential for my BDR, 3:46 would be great, Any suggestions? I found one on E-Bay with 180K miles and still want $500........
Jeeze........ I currently have a open 3:46. Hopefully someone knows where I get find a good used one.
Vance
Old 04-11-2017, 05:39 PM
Grey 65's Avatar
Serg has built 3 diffs for me.
3.15 40% lock
3.46 60% lock
3.91 40% lock
That is my car in his ad. He rebuilds the diffs and they hold up. I autocross my car and put more stress on the E36 diff than anyone else in the country and have not had a failure with anything Serg has built for me.
You need to be aware that the E36 diffs are held in by 3 bolts. I know you have had the rear 2 out when you had the diff cover off before. But bare in mind that the front bolt on your car is 14mm. If you get a diff that isn't setup for a BDR it will be 12mm. You will have to tap the hole in the diff to 14mm.
BMW E36 3.46 LSD POSI DIFFERENTIAL LIMITED 40% LOCK 325I M3 BACKDRAFT COBRA | eBay
Kevin.....
Old 04-11-2017, 06:07 PM
Axel 427's Avatar
Thank you sir
