01-16-2004, 10:51 AM
Tx
Cobra Make, Engine: Empty handed for the moment
"Run" stand for my side-oiler
Ahhhh....the motor is back home
I'm thinking about building a "run" stand for it. Anybody done this? I know what I need for the electric, cooling, fuel, and exhaust systems. But what material should I use and how should I build it??
Should I put it on casters? What material for the exhaust hoses at the headers and how do I keep it from choking the engine?
Thanks guys,
Charmer
01-16-2004, 11:29 AM
IL
Cobra Make, Engine: Midstates work in progress, personally built 302
Charmer,
I built this stand to run mine. I got a used radiator with fan and picked up the hoses from a local automotive place.
The headers and pipes are the ones for my car - I just ordered them ahead of time. At first I just ran with headers but the noise and the fact that I DO have neighbors called for the sidepipes.
The frame I actually purchased from Northern Tools for about $40 - it saved me from welding it all up. I added some channel for the radiator support, a used lawnmower gas tank, bought my MSD ignition, a used battery, and voila. Total cost was about $200 but the peace of mind that everything works is "priceless" as the commercial goes. I used my car dollies under the base, but those were hard to keep seated and the rubber caster wheels I had were too weak. I have the whole thing on a platform of wood with steel caster wheels screwed to the wood right now and that works great for moving it around. Don't worry about it tipping or anything: as long as there is nothing hooked to the flywheel, there's no torque to try to tip it.
I mounted the starter to the bottom of the frame with a plate. I just eyeballed the location and made slots in the plate to be able to mesh it with the flywheel. Don't make my mistake and mount the starter to the back - it happens to rotate the engine the wrong way....
Zipzip
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
01-16-2004, 02:13 PM
Tx
Great job
That's perfect zipzip!!
That's just what I want to do too. Just to make sure the motor works. I was wondering about the starter! So you bolted a piece of plate steel to the wood platform and then bolted the starter to the plate steel? Sounds like it would work fine. Thanks so much for the info. If you got any more pics of your handiwork with the plate steel, I'd love to see them.
Charmer
01-16-2004, 05:31 PM
IL
Here's a little more detail
01-16-2004, 05:33 PM
IL
Another view:
01-19-2004, 07:15 AM
Tx
Great view!
Those are really helpfull pics, zipzip. Thanks!! It'll be Spring break before I get started on mine but your pics have really helped me create my "packing list" for what I'll need and how to build it.
Charmer
01-26-2004, 11:10 AM
Hi Stretch,
I saw that you're online right now, so I thought I'd let you know I've got room reservations for the end of Feb.
I'll look forward to seeing you then, and giving you that promised ride. Also, I still have the "surprise" to give you.
See you soon,
Ted
"Rocket Man"
Ted Parrish
01-29-2004, 02:10 PM
Tx
Awesome Ted!!!
Can't wait to see the "Rocket's Red Glare"! I'll be at the hotel early on Friday to welcome everyone and get things set up. Look forward to spending some time catching up with you and Pam. Oh yeah, the "suprise"!? Well, whatever you have done to the rocket, I'm sure it's very cool.....but what could it be???  tires?  motor mod?  hmmmm.... It's bad enough knowing that I'll get to see the car  let alone that there is a surprise involved!
My wife keeps ribbing me about having to bring the boys to see me in jail after I get thrown in the slammer for trying to steal the Rocket back from you
Take care,
Charmer
_______________________
Stretch Williams
"A snake in my garage is worth two in your trailer" - me
