Old 03-28-2004, 08:32 AM
Send a message via AIM to joe garland Send a message via Yahoo to joe garland
Smile Brake proportioning valve
I can't tell if I am making a differance when I try to adjust the valve, any suggestions?? Where is a good starting point, all the way shut?
Thanks for any tips!
"Uncle Joe"
JustJoe
Old 03-28-2004, 10:16 AM
Tom Wells's Avatar
Hi Uncle Joe,
Here's a quote from the Wilwood FAQ page:
Q: When do I use a proportioning valve?
A: A proportioning valve is a pressure reduction device. It is typically installed in the rear brake line to reduce braking efficiency and compensate for premature wheel lockup; a result of incorrect front to rear brake bias. An adjustable proportioning valve permits incremental adjustments to fine tune brake bias.
You need a place to stop from speed that has no, um, fixed barriers, if you know what I mean. If you lock the back tires under braking the car is unstable
What you need to do is to get the fronts to lock up just before the rears.
Tom
Old 03-29-2004, 04:18 PM
Thanks Tom!! Got things working well.
Joe
JustJoe
