04-05-2006, 01:15 AM
Administrator
Wa
TWM Induction systems for your Cobra from Thor Motorsports.
From member thorconstr,
Thor Motorsports
Competition Fuel Injection
Systems and Accessories
2609 North Forgeus Avenue
Tucson, AZ 85716
520-401-9142
Al Wohlstrom
thorconstr@msn
Pricing for TWM 427 Ford Injection
TWM 427 58mm kit, includes manifold for distributor, 4 two barrel 58mm throttle bodies, fuel rails, manifold mounted linkage, vacuum lines with plenum and air horns.
Bosch 42# or 65# injectors.
Aeromotive A1000 fuel pump, regulator, and filter.
F.A.S.T. XFI ECU, harness and O2 sensor.
MAP, water, and air sensors.
Crank trigger.
Polishing for manifold, throttle bodies, fuel rails, and air horns.
Shipping for the above.
06-13-2006, 04:37 AM
Cobra Make, Engine: ERA 427" 351W
TWM induction
Ford 289-302 IDA kit, Ford 351 IDA kit, and small block Chevy kit are $3,410.00
Ford 460 kit is $4,680.00.
Al W.
06-13-2006, 11:30 AM
TN
Cobra Make, Engine: Ford F100; 496 Shelby, MassFlo, BlueThunder, Kee-Al-TopLoader, Detroit Locker
Help me out just a bit, please. Confirm that the price is $4050 plus another $5,000 for additional components? That would total nineish?
Super Chief
06-13-2006, 01:01 PM
Mo.
What Scott M Jackson said.............................
06-13-2006, 01:31 PM
Polishing is a $1,500.00 option. If you did not use a crank trigger and no polishing it would be an additional $3,680.00 or $7,730.00 total.
Al W.
06-13-2006, 09:08 PM
Cobra Make, Engine: CSX4815
F.A.S.T. xfi software
Al,
Are you using the fast controller on your car? If so, do you do your own tuning with the software? How steep is the learning curve with the software?
Thanks Al!
06-14-2006, 06:09 AM
Mike, I am using the FAST computer and I can make a copy of my program. I have a couple of guys that are excellent with computer tuning, but from what I've seen FAST is pretty user friendly.
Al W.
06-14-2006, 07:28 AM
Thanks Al! I'll be giving you a call to discuss my options. What is the best contact # to reach you at and what time? Thanks again!
06-14-2006, 07:39 AM
Mike, 860-790-0140 Call between 7am & 8pm EST. Thanks, Al
Al W.
08-29-2006, 12:08 PM
New phone # and address change
I just recently moved, my new address and phone # is:
Tucson, AZ 85716
520-401-9142
Al W.
09-11-2006, 07:30 PM
Cobra Make, Engine: Autocraft MKIV
THOR .. .so tell me your a distributor for the TWM IR EFI set ups. I have a custom intake being made for my 351W 9.2 w/ C302B's and it will have the injector ports ... so whats a set up like this go for ???
09-11-2006, 08:21 PM
Hey all,
I got to tell you, I saw this set up over the weekend on Al's car and it is really a thing of beauty, both physically and performance wise. "Wow-factor" doesn't begin to describe it!
09-12-2006, 09:41 AM
Ron, We make a manifold for a 351W, why go to the added expense for a manifold that may not work properly?
Al W.
09-12-2006, 09:46 AM
Larry, I enjoyed talking to you, Dave, and your dad. Dave's car looks great and sounds nasty too! Give me a yell if you need a hand with your car. Keep in touch.
Al W.
09-12-2006, 12:08 PM
Cobra Make, Engine: Alum bodied CSX4266, fuel injected alloy 472, 663 hp Engine built by Dralle. Suspension by Tom Barnard
Al, who's air filters do you use? Did you have to modify the hood to allow the front leading edge of the filters to clear?
Don't underestimate the predictability of stupid!
09-12-2006, 12:31 PM
filters
We have filters that go on our shorter nostalgia stacks that use a Weber type filter. Thats what I am using on mine presently. We have a vendor that is in the process of making some billet aluminum filters.
I did cut the scoop opening larger in the front because the hood was impeding air flow to the front two injectors.
Al W.
09-12-2006, 02:57 PM
Al, I am running the TWM setup on my CSX car. It was installed by Dave Dralle and has Lance Nist's computer management system on it. I am currently running ITG banana filters. I am looking for a filter system that is easy to install and remove quickly. The TWM setup is awesome!
09-12-2006, 03:06 PM
THORCONSTR .... the intake I need you dont have ... I have a 351W block with C302B heads they are 351C style heads. it will be a 383 stroker. Its really for my Pantera sorry ??? LOL But I did coordinate putting IR EFI on it .... the fabricator uses it to use TWM components.
09-12-2006, 03:58 PM
Ron, We also have a manifold for a 351 Cleveland. It's about $100.00 more than the 351W.
Al W.
09-12-2006, 04:03 PM
The Weber type filters look better than the ITG (IMHO) but are a bit more time consuming to put on and take off. Do you have any pictures?
Al W.
