06-01-2008, 11:29 AM
Cobra Make, Engine: ERA 427" 351W
Billet Aluminum Hemi Heads for SB Ford & SB Chevy
Do I have your attention? I am going to be offering these heads on my site!
They will be complete and ready to bolt on. T&D rockers, valves, springs, carbon fiber valve covers, etc. These are billet aluminum hemi heads. They are made by a wizard in his shop. He has a set on a SB Chevy, naturally aspirated, race gas, in a Chevy II running in a 10 1/2 in slick class, producing over 900hp, turning 8.14 at 173 mph. This is a pretty nasty engine granted, but these heads on a street engine would produce significant hp gains, not to mention looks! No, they are not cheap! Al W.
Al W.
06-01-2008, 12:28 PM
Cobra Make, Engine: Cutting Edge, Boss 429
Okay Al, I'll bite. I don't see a link or any other obvious way to your site, and a little more info would be nice. You do want to play nice don't you Al?
06-01-2008, 01:50 PM
Boss, They will be on my site soon. www.thormotorsports1.com Thanks, Al
Al W.
06-01-2008, 03:19 PM
"They are made by a wizzard in his shop".
Who's shop??
Who is "he"??
Chas.
06-01-2008, 03:28 PM
Just a guy in a machine shop, he has a long career and experience in performance parts and racing. He has held records and still does hold a record at Bonneville. As seen by his work, he does know what he is doing. He is in the process of patenting the head design.
Al W.
06-01-2008, 04:21 PM
06-01-2008, 04:36 PM
Except that those heads are cast, not billet! Huge difference.
Al W.
06-01-2008, 06:48 PM
va
Cobra Make, Engine: BDR #250
I want,NO HAVE TO HAVE them!!!!
06-01-2008, 06:56 PM
Stolen Avitar
GA
Looks quite Boss 429ish. I'd like to see some more details like flow rates, manifolding etc.
Steve
06-01-2008, 08:50 PM
Banned
For what a pair of those heads will cost I probably could buy a good used Cobra (complete) in today's market.
They are nice though...good luck with your new product.
06-01-2008, 08:56 PM
SI
I would like to know more about the cooling efficiency and results from extended duration hi-load dyno runs for street & circuit type race use . Drag race results of limited duration prove the porting & flow rates are good. Actual water jacket volume & coolant surface area appear to be minimal if they are indeed cut from a one piece solid billet.
Jac Mac
06-01-2008, 09:21 PM
I believe you'll find that the heads are machined by Chuck Haberstrate. He also machined the Arias hemi/chevy heads in the recent past. The guy has been around and does great work.
Correction on his record though. He currently holds a record at El Mirage not Bonneville.
06-01-2008, 09:26 PM
Michael, I believe you are correct. He's a pretty talented guy isn't he?
Al W.
06-01-2008, 09:48 PM
El Mirage, I stand corrected. Thanks!
Al W.
06-01-2008, 09:59 PM
No problem.
& Yes he is talented.
06-02-2008, 05:58 AM
Steve, The heads were fashioned with a Boss 429 look. I'll get some flow data for you.
Al W.
06-02-2008, 06:37 AM
Tx
Cobra Make, Engine: Classic Roadster, 408 LSX
Will they require custom headers or configured for an off the shelf design?
I've spent most of my money on cars and women. The rest I wasted.
06-02-2008, 06:41 AM
G, I will check on that for you.
Al W.
06-02-2008, 07:05 AM
OR
I saw a set of these heads on a car at the Portland Roadster show last fall. The guy who had them on his car said they were a prototype and they would be available for sale about this time frame.
Talked to him awhile and he said the target pricing was in the $5500 range or so. I'd sure like to see some testing numbers and flow numbers on these heads. They look really unique mounted on a small block Chevy motor. Definitely a real "wow" factor with these for bling.
06-02-2008, 02:59 PM
headers
A header flange can be had to work with regular headers.
Al W.
