2Likes
08-31-2018, 11:58 AM
IN
Yeah, I found the Gorilla nuts and ordered some today.
Thanks again!
Tom Walgamuth
09-06-2018, 01:16 PM
IN
Originally Posted by TexasSnake
I have a spare set of 16 inch Compomotive HB wheels that may provide a solution for t.walgamuth. They are 5x4.5 bolt pattern.
Hi Tex. I got my center section repiard now. I might be able to use your outer rim on my wheel. Mine is bent a bit. Can you give me dimensions of the wheel and rim please?
Tom
09-07-2018, 05:35 AM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Tom, I sent you a PM regarding the Compomotive wheels.
09-12-2018, 04:35 PM
IN
Thanks Tex!
09-13-2018, 07:09 AM
IN
Can these compomotive wheel centers have five lug holes added in the blank spaces? If so who would do that please?
09-17-2018, 05:24 AM
If it can be done, any competent machine shop should be able to do it for you, although you might gawk at the price.
The best thing to do would be to make a drawing, even a hand drawing, of exactly what you want so there is no confusion. If you need a few shops, I might be able to get you a few.
09-17-2018, 07:43 AM
IN
Thanks Joy!
Upon further inspection the place on the front which looks like a good place to drill additional holes is a void behind, so would not work for me.
Thanks for your thoughts!
10-16-2018, 05:06 PM
Compomotive Rims
Are these rims still available as I need 2 - 17" rims, one at @ 8' wide for the front and then the rear at @ 10" wide. I am utilizing Mustang spindles on my current cobra so I believe the lug spacing specs should match. If they are still available, please let me know and I will get the actual measurements and backspacing specs that I will be needing to replace and see if we have a possible match.
10-18-2018, 05:59 AM
Just discovered your post. Yes, I still have the 17” Compomotive HB wheels. Widths are 8 and 10 and are Ford bolt pattern. The wheels are in like new condition.
10-25-2018, 09:39 PM
Thanks for the reply, will attempt to confirm the specs needed for the replacement rims this weekend.
10-26-2018, 12:58 PM
If anyone buying your wheels does not need/want the slip-on spinners,
I am open to purchase them. Thanks.
10-26-2018, 04:17 PM
Unfortunately, the spinners for these wheels have been sold. I actually had two complete sets of Compomotive spinners. Sold both sets a while back and could sell several more sets if I had them.
11-04-2018, 08:03 AM
I will be needing a 10" wheel with a 6" backspacing and then a 9" wheel with a 5.5" backspacing. Both 17" lug style wheels with the Ford 4.5 bolt pattern.
If you could please confirm if the two rims you have would magically have these specs and let me know, I would greatly appreciate it. Thanks
11-09-2018, 01:54 PM
Wheel Measurement
I will send you a PM
