4Likes
3
Post By wrogers55
Post By Clois Harlan
05-08-2014, 04:02 PM
recommended tires for track and street?
Have 17" wheels and plan on 3-4 track weekends per year. Any recommendations?
05-08-2014, 04:08 PM
Nitto nt05
05-08-2014, 06:01 PM
tx
Khumo Ecsta XS are pretty good too.
180 treadwear so they are reasonably sticky for the track and you get decent life out of them on the street.
05-08-2014, 06:03 PM
ny
Cobra Make, Engine: SPF
Just put Nittos on tonight; love them
compared to the BFG.. ROCK HARD tires.. anything may have tickled my fancy.
05-08-2014, 06:14 PM
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Nitto NT01
If you behave on the street, they will last and never let you down.
And they will hold 600+ HP in second easily. Once at operating temp on the track, they will grip like a slick.
Heat cycle them before you put them on or the wear will be about 1/3 of what it can be.
Stay out of the wet.
Best of luck,
Wayne Rogers in Hideaway, Texas
05-08-2014, 06:25 PM
thanks all...
any experience out there with toyo r88's?
wayne, how do you heat cycle a tire before you install? thanks.
05-08-2014, 06:40 PM
Answer: To heat cycle before mounting:
Most retailers have access to ovens where they can heat and cool the tires on rollers with pressure or static. You usually have to ask and press them to call their suppliers to get the service.
Just an example, Discount Tire (also American's Tire) offers the service for $20 bucks per tire. But you have to ask and have the local shops call their distribution house and you will get the right answer. After they are cycled, most suppliers put a small red circle stamp about half the size of a dime on the sidewall. Don't underestimate the effect of this. If you can give the tires a week or 10 days after the heat cycle is done you will get the best possible compound you can have on that tire. Gives time for the polymer chains to slowly link up and you end up with the same grip but much tougher tear resistance.
05-08-2014, 06:56 PM
tx
Or you can do it on the track.
More effort but lots more fun.
05-08-2014, 08:02 PM
Originally Posted by kctexmex
thanks all...
R88 is similar to NT01 with different tread
05-09-2014, 11:44 AM
OK
buy a cheap set of wheels and put a set of slicks on it when you go to the track. You will be amazed at how much contact one of these guys for some almost new slicks for cheap:
jphglobal1@gmail.com or John Berget Racing Tires
I have bought from both of these guys and have never had any issues. In fact several time the slicks had never been on the ground.
Clois
"Let's roll"
"Be part of Something Good
05-09-2014, 12:02 PM
Nitto NT01
E. Wood
ItBites
01-04-2015, 01:18 PM
Any of you Nitto NT01 users have any observations on extended use?
I am also interested in longevity on the street.
01-04-2015, 03:02 PM
285 front/315 rear. 6K miles, some track time, 150+ autocross runs, still legal tread with a little more wear on inside due to negative camber. 18 psi street / 26-28 psi autocross.
01-09-2015, 03:39 PM
OK
Cobra Make, Engine: Fords
Give these a look over, GoodYear F 1 GS-D3.
http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
I've had two sets of these, one 16" and one 17". They gave me some incredible track experiences, as well as street use. They won a tire competition a few years ago.
Z.
'65 K code Mustang
'66 Galaxie 500
