Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Like Tree30Likes
Old 11-19-2017, 10:38 PM
racco's Avatar
I have decals now, but I'm sending a sample to be made in rubber for a more permanent solution.
Old 11-19-2017, 10:49 PM
nobby's Avatar
Cobra Make, Engine: DAX 351 windsor
Sounds good.
Old 12-14-2017, 08:24 PM
sracer5's Avatar
Cobra Make, Engine: ERA #294 , Center Oiler FE
Im interested also. Plan on buying Avon’s in January.
Old 12-16-2017, 07:23 AM
wolf k's Avatar
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
free image hosting sites
I custom ordered this set from Tire Stickers, along with the blue line.
Sanded off tire lettering for a smooth surface, then glued the rubber letters and lines with supplied glue included in the kit. Looks authentic and seems durable.
BigGuy, nobby, ACademic and 1 others like this.
Old 12-16-2017, 06:39 PM
DanEC's Avatar
That looks really nice. What tool(s) did you use for smoothing the sidewalls first?
nobby likes this.
ERA 782 Running
Old 12-17-2017, 06:21 AM
wolf k's Avatar
Neutral
I experimented with a a couple of different procedures and tools.
What worked the best was a 3" medium scotch brite pad on a 1/4 arbor mounted in an angled air powered die grinder.
It went fairly quick and had good control.
Old 12-17-2017, 10:16 AM
racco's Avatar
Very nice
Old 12-18-2017, 02:53 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
I had pin drive wheels on my first Cobra, they were a pita ....always had a vibration.....now I have the lugs and they are smooth as the baby's bottom...
Billboards ....no way...
Old 12-19-2017, 07:03 PM
nobby's Avatar
What was involved for the custom order from tire stickers? Just a change of size?
Old 12-20-2017, 06:25 AM
wolf k's Avatar
^ It was fairly involved, all I had was a photo off the internet of an original blue streak tire. I sent that image to Tire Stickers. We went back and forth with with several computer generated renderings. Finally agreed on one, stickers were made and sent, however, the letters were wider then our agreed rendering. Sent those back, It took three sets until this current set was acceptable.
It was a hassle, but Tire Stickers as a company was accommodating to my requests. The ideal way for them to make exact copies of the original blue streak lettering would be to send them a tracing off an original tire.
Old 12-20-2017, 02:08 PM
Cobra Make, Engine: NAF 427
Great stuff racco and wolf k.
Have either of you also considered the "BLUE STREAK" lettering to go on the "bottom" of the tire sidewall.
Tire Stickers looks like a good source of custom lettering.
wolf k: for the blue stripe, did you send a tracing or did you provide a set of dimensions (diameter, width etc)? If so, would you be willing to share the dimensions you used?
Were the dimensions unique to your tire size, or were the dimensions per the vintage tire size?
I am shooting for the original Blue Dot street tire look of the 427 Cobras and I have the "blue dots" available.
Greg
Old 12-20-2017, 02:13 PM
Here's what the "blue dots" look like on my BF goodrich tires.
Now to smooth the sidewalls and order the Goodyear and Blue Streak lettering and put them on.
Greg
  #33 (permalink)
Old 12-20-2017, 02:16 PM
By the way, here was the e-bay find that was the source of my "blue dots".
A very close match to the original color.
Greg
66gtk likes this.
  #34 (permalink)
Old 12-20-2017, 06:44 PM
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
I opted for the Michelin TB15 tires through Coker tire, I wanted a performance tire with the correct sidewall to accommodate the "billboard" transfer stickers.
  #35 (permalink)
Old 12-20-2017, 06:53 PM
racco's Avatar
Greg
Looks real, I just don't trust the bf tire on a high power car.
  #36 (permalink)
Old 12-20-2017, 09:12 PM
Hi racco. OK. Busted.
BFG's are not a high performance tire.
But then again. I'm a boulevard cruiser and I don't track the car.
A lot of Cobra mishaps have happened on high performance tires though.
Drive carefully.
Greg
  #37 (permalink)
Old 12-21-2017, 04:27 AM
wolf k's Avatar
Greg
The blue stripe is an "off the shelf " product from Tire Stickers. You have several choices of width, I selected the narrowest at 1/4 inch. They come in four segments per tire. For the diameter, I simply followed a line that was molded in my Mastercraft tires. I believe the original blue streaks had the blue line more in the middle of the tire than were I placed mine.
  #38 (permalink)
Old 12-21-2017, 04:31 AM
wolf k's Avatar
CSX 4133,
I would really like to see pics of your car with the Michelin TB15 tires. What sizes did you go with? How do they perform?
  #39 (permalink)
Old 12-21-2017, 04:28 PM
nobby's Avatar
Thanks for the info wolf k. Wonder if tire stickers kept the dimensions of your final letters for anyone else to order?
66gtk likes this.
  #40 (permalink)
Old 12-21-2017, 06:05 PM
wolf k's Avatar
I will contact them and let you know
