Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-22-2018, 07:19 PM
ACHiPo's Avatar
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Default Safety Wire Pliers
Well, the safety wire pliers I bought a couple years ago gave up the ghost today after using them to wire all of 8 (or was it 6) knock offs. They came from Finish Line. Pretty disappointing. Just ordered a pair or Milbars for $70--hoping I get at least 3x the number of wires twisted.
What are others using?
In my case the plastic "die" that guided the twist motion stripped out. I may try to pull it out and see if I can't find a more durable material. In the mean time hopefully the Milbars will hold up a bit longer.
Old 04-22-2018, 09:01 PM
twobjshelbys's Avatar
I bought the ones from Harbor Freight. They were very high quality and inexpensive (not cheap).
Tony
CSX4005LA
Old 04-22-2018, 09:09 PM
CC Member / Sponsor
You will like your Milbars. They build them for Snap On.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 04-23-2018, 04:38 AM
joyridin''s Avatar
Actually, Stride Tool makes them for Milbar, Snap-On, and quite a few others including Chinese versions.
The Milbar and Snap-On are made from square stock and machined completely. The Chinese versions are castings with a small amount of milling just to make them usable.
Old 04-23-2018, 04:53 AM
Senile Club Cobra Member
We have found the Harbor freight pliers will often not cut the wire, the blades are not precise enough to reliably cut the SS wire. They twist OK, but you will need decent dykes for the wire cutting.
rick@autoventureusa.net
Old 04-23-2018, 08:36 AM
HI Cobra's Avatar
I have the Harbor Freight 6" and 9" wire twist pliers for several years and no
issues.
Flip
Old 04-23-2018, 10:06 AM
undy's Avatar
issues.
Same here. I cut the wire with them too, no problem.
Too many toys?? never!
Old 04-23-2018, 10:52 AM
Look. The reality is that almost all Harbor Freight tools are meant for light duty (note 1). If you're a pro and will use them daily spend the money and get something that will last. Meanwhile, for the same money you can typically buy 3 or 4 HF tools for the same price, but you'll be swapping wheels once a year if that often, and the HF tool will work nicely.
PS. HF has two versions, get the "long" one.
Note 1: Some of their tools, especially their light weight low profile floor jack, are among the best. I bought one and my friend bought two for his mechanic shop.
Tony
CSX4005LA
Old 04-23-2018, 11:52 AM
We have some HF tools in the shop. There are some very good items......and some real crap! The 3/8" to 1/4" drive adaptor snapped at about 2 Lb./ft. of torque!
Old 04-24-2018, 09:43 AM
Karl Bebout's Avatar
I have a HF 9" wire tool and it doesn't cut well, but spins just fine. Its my 2nd because the first one's locking tang broke. HF replaced it with no questions asked. The vast majority of their hand tools have a LT guarantee. Hard to pass up, considering the price. Of course, its mighty frustrating for a tool to die just when you need it....My 2¢
Karlos
Old 04-24-2018, 11:14 AM
DanEC's Avatar
Their (HF) aluminum jack stands are nice and they carry urethane pads for them. I also have one of the 1-1/2 ton aluminum jacks for light work.
ERA 782 Running
