Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Like Tree3Likes
Old 07-21-2023, 10:44 PM
Cobra Make, Engine: 1965 Contemporary Classic. 427 side oiler (I think)
Default Need a spinner vendor
First off you guys are great! I asked for advice on removing spinners and the responses were both amusing and sarcastic.
I like that.
Great ideas and I’ve tried most of them.
Here is a rundown that I hope you find enlightening:
Started with my dead blow hammer as I didn’t have a clue what I was doing.
Moved onto the 9-11 tool and a lead hammer.
Didn’t work.
That got the front off, but not the back.
Purchased the large aluminum tool and a breaker bar.
Didn’t work.
Added 6’ of pipe to the breaker bar.
Didn’t work.
Got a 1/2” impact wrench.
Didn’t work.
I should mention that I have been marinating the spinner in everything from Kroil oil to ATF and acetone.
Got a torque multiplier.
Didn’t work.
Had a friend bring over his 1” impact wrench.
Didn’t work.
And before you ask I’m sure I’m spinning them in the correct direction.
Cooled the spindle with dry ice and heated the spinner.
Didn’t work.
It was suggested that I take the yard that works on truck tires and tell them “I’ll bet you $100 you can’t get those spinners off”!
Anyway by now you can hopefully see why I’m at the stage where I want to cut them off.
When I figure out how to upload photos I’ll pass the along.
Looking forward to more creative suggestions.
Dave
Old 07-22-2023, 03:20 AM
Sawdust's Avatar
Before you cut them off go to Cobra Valley’s website and take a look at their Spinner 9-1-1 removal tool. It’s a must have.
Old 07-22-2023, 04:59 AM
I agree with Sawdust. I also recommend Kroil penetrating oil.
Just and idea, drill a very small hole in the spinner and shoot the Kroil in it and keep the hole full for several days. Then a rim repair place can repair the hole.
Old 07-22-2023, 05:22 AM
DanEC's Avatar
Find one of these or borrow one that Sawdust recommended. Good chance it will work.
Sawdust likes this.
ERA 782 Running
Old 07-22-2023, 08:42 AM
venum14's Avatar
Cobra Make, Engine: Bennett Cobra
Not sure if you tried heat from a small torch...assuming the spinners are aluminum they will expand quicker and dimensionally more that the steel hub. After heating apply the penetrating oil. When I remove/install my spinners, I use a 3" diameter glass filled rod about 16" long. When it's hit with a large hammer it creates a solid blow transferring all the energy to the spinner.
Jeff
Old 07-22-2023, 09:25 AM
eschaider's Avatar
I am an echo of the recommendations already made, but you should definitely have one of the Cobra Valley Spinner 911 tools. It is waaaaay less expensive than replacement spinners and will make you glad you bought it every time you use it. Heating the spinner and using penetrating fluids does not hurt, but there is no substitute for the mechanical advantage the 911 tool provides to you.
Just do it! You will not be sorry.
Alfa02 likes this.
Old 07-22-2023, 09:44 AM
Be careful not to melt the spinner with a torch since aluminum has a much lower melting point that steel. Also don't get it so hot that the wheel bearings are affected. I used the Cobra Valley 911 tool with success but I did have to combine that with several very healthy whacks of my lead mallet. BTW, Cobra Valley also sells some very good anti-seize that is a clear liquid that is much less messy than the silver stuff. My 2¢
Old 07-22-2023, 11:11 AM
Originally Posted by Snek View Post
And any suggestions on the best way to cut them off?
Don't. You'll end up damaging your hubs. There's half a dozen good spinner removal tools. Just pick one and try it. Or, build your own. The one I built will literally spin the tires on asphalt with a troublesome spinner. Just apply the brakes or put it in gear for the rear wheels. 5000 ft/lbs of torque will break loose any spinner out there, unless you confused your antiseize with JB Weld.
Old 07-22-2023, 11:30 AM
twobjshelbys's Avatar
5lb American Hammer mallet on each ear in succession will break it loose. You have to hit each one. Just one won't do it. You cannot use lead shot hammers they will not transfer enough of the energy to the wing. You need direct contact of the entire mass of the head. Tire must also be on the ground or you're just moving the wheel around.
Blue66 likes this.
CSX4005LA
Old 07-22-2023, 12:27 PM
... and by the time you get it off you will not be able to lift your toothbrush with that arm.
Old 07-22-2023, 12:29 PM
... and around the 15th whack you'll catch the edge of the fender. Use your brain, not your arm.
Old 07-22-2023, 04:05 PM
Are you selling that contraption? It's probably beyond most people's here skills to build one...
Here's why to use a little muscle...
All of these solutions are money spent that you'll use
ONCE
AND PRECISELY ONCE!
Why?
Because having wrestled with the hammer and spinner you'll learn your lesson and put anti-seize on the mating surfaces and never have to use anything but the hammer, and only lightly at that, again...
CSX4005LA
Old 07-22-2023, 04:24 PM
Originally Posted by twobjshelbys View Post
Are you selling that contraption? ...
No, that's why I wrote "There's half a dozen good spinner removal tools. Just pick one and try it." in my first post. But I don't buy in to "they'll learn their lesson on anti-seize" stuff. He's in a jam and needs a solution, and taking a high speed Dremel cut-off wheel to his spinner ain't it, but he thinks it is. And forcing him to get an arm injury just to learn that he can't swing the hammer for an hour in his garage ain't it either. Have some compassion, Tony.
Old 07-22-2023, 04:53 PM
Cobra Make, Engine: era#671 Keith Craft Motor
Patrick,
As a Clubcobra Member since around 2003 or so , would you be nice enough to ship your spinner removal tool to the East coast Free of shipping charges and then a return label enclosed as well ... I just need it for a few days
Old 07-22-2023, 04:55 PM
Originally Posted by sgianino View Post
Patrick,
For you, yeah.
Old 07-22-2023, 04:57 PM
Great Idea, But why stop at 5 LBS go for the 20LB Sledge and get a running start from the end of driveway !
Old 07-22-2023, 06:44 PM
mrmustang's Avatar
Gold Star Contributor
Patrick,
There is a member here, also with a Contemporary, who lives in NJ who has the same tool.
Just saying
Bill S.
Old 07-22-2023, 06:50 PM
No, that's why I wrote [i]"...He's in a jam and needs a solution, and taking a high speed Dremel cut-off wheel to his spinner ain't it, but he thinks it is. And forcing him to get an arm injury just to learn that he can't swing the hammer for an hour in his garage ain't it either. Have some compassion, Tony.
Well, come on. How many times has your Cobra had an issue and you said "I've got to get this fixed right now or the world will come to an end"? My spinners were stuck. But it was not essential that they come of right now. So I got the American Hammer (from the guy at AH that used to give forum members a smokin deal). Took a few smacks at it and figured that rotation was the key and had all 4 off in an hour or so. Yeah, some of the angles with the hammer were inconvenient, but nothing that was going to create permanent injury (our bodies and brains tend to regulate these kinds of activities).
Nothing about a Cobra screams urgency. It's a recreational vehicle.
I gave up years ago buying the most expensive tools that I use once. And extend that to the right tool that will not wear out before I die. So the Harbor Freight safety wire pliers were perfect for me (oh and by the way, it's the same one that Amazon sells...) On the other hand I did buy a whole bunch of Hitachi air tools (framing nailer, stapler, finish nailers) because they could take the abuse.
To the OP. Take your time. It'll work out.
CSX4005LA
Old 07-23-2023, 05:54 AM
I was just giving Patrick a hard time....Just wanted to see if he would really send it to me
Just saying
Bill S.
Old 07-24-2023, 02:51 PM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
Candle wax and a cigarette lighter may be the solution? I have not tried this, it's cheap and easy, can't hurt to see if it works. See the attached link to a youtube video explaining the technique.
https://www.youtube.com/watch?v=KFdFsfSAuyc
