| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
04-22-2009, 09:23 PM
AZ
Cobra Make, Engine: Superformance # 2855,408 AMP Performance Stroker
Tires
Okay I know everyone is tired of posts regarding tires, all I want to know is what sizes (15inch wheels), styles and where are you buying the Avon's that you all are talking about. I have a new SPF roller and I would like to take the brand new BFG's off and replace them with a softer compound tire before I put it on the road the first time.
Thanks for the help.
Cobraltd
04-22-2009, 10:22 PM
il
Cobra Make, Engine: #1459 w/460(sold)New(used),spf w/427s.o.(sold)
why dont ya burn those up first. Look into the M/T SR's. I think there a bit cheaper, unless money doesnt matter. Make sure ya bump down the air pressure on the bfg's to about 20-22 lbs. Car will ride much better.
04-22-2009, 11:03 PM
AZ
Thanks Sparks for your suggestion on the tire pressures. I have 275's on the rear and I am anxious to put on 295's. Hoping to recover some of the cost by selling the BFG's.
04-22-2009, 11:10 PM
il
The size wont matter near as much as the kind of tire. Good luck. I can spin my tires at will in first 3 gears, your car will have much more power than mine. BE CAREFULL..
04-23-2009, 02:19 AM
Cobra Make, Engine: ERA #696, Ford 427/482 CO
HOB
04-23-2009, 02:38 AM
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Good call in ditching the BFGs. Your car will be a completely different vehicle with the Avons--with much better traction and handling (certainly vs. the BFGs).
I run the 245s up front and the 295s in the rear (the larger tires on the Roger Kraus site).
Good luck.
04-23-2009, 07:32 AM
il
Did I read that rite ? $300 plus for avons?
04-23-2009, 09:49 AM
CA
Cobra Make, Engine: SPF #1019
Yup! I look at it this way: it's important to have high quality tires, since that is the part of the car that touches the road
04-23-2009, 10:20 AM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
The last time a car got away from me I was doing about 95MPH (Lime Rock - downhill). When the back end is becoming the front end $300.00 per (sticky) tire does not seem very expensive. The loss of control cost me $4,000 (car damage) plus broken bones.
Just my $0.02.
Bob
ca
Cobra Make, Engine: SPF 239
Two words
DRAG RADIALS
+1, if you can afford it. I think the back tires are $400.
04-23-2009, 10:57 AM
Originally Posted by D-CEL
Two words
DRAG RADIALS
nuttin' hooks like them..
I'm running the M/T ET Street drag radials, 315/35/17. They hook good enough to yank the front tires  The 35 series allows for minimal sidewall flex for the twisties too.
Dave
Too many toys?? never!
