Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Old 05-10-2009, 11:55 AM
Larry N Johnson's Avatar
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Default Restoring Billboards
Rather than hyjack another thread, this new thread is dedicated to results on restoring Billboard tires.
FUNFER2 asked
Tell me how you applied the paint.
Brush/sponge brush. Any brush marks.
Coats.
Time.
Have you drove it much since.
Tips.
ect.......
You did a great job.
Kevin
Kevin,
No secrets here. My goal was to keep the "stenciled look", so the overspray was left in place. Simply touched up the letters w a small bush that came ordered w the Ranger paint from http://www.rangerpaint.com/. Single coat primarily, two coats where the whilte was inadequate.
There as small brush marks if one gets close, but that is not normal. The tire has a "look" that goes w the car, so close ups are not so critical. I did retain all the stencil features like the A triangle, split D, etc. W the overspray left left in place, they look the way I want them.
How did you do yours?
Old 05-10-2009, 03:58 PM
FUNFER2's Avatar
I have yet to mount and paint mine. I did buy the Ranger paint and some quality art brushes. There is a guy here that has the stencil's for spraying the paint. I almost bought one but, I'll try the brush on for now. Being an auto body man, I thought of using the flex paint for bumpers. hum....?
I like a mild tire dressing for shows. I wonder is it will have an effect on the paint once cured ?
It would take a lot of time to wipe on the dressing around all the letters, so it does not get on the paint.
Kevin
Old 05-11-2009, 11:35 AM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
Hi Kevin,
Can you put me in contact with the person that has the stencils? Thanks,
- Fred
Old 05-11-2009, 12:05 PM
noblec5's Avatar
Cobra Make, Engine: FF Daytona Coupe #211, SPF,1037 sold
I think for the stencil's you can go to www.racelinedigital.com They have both the Goodyear and Avon stencil's
chris
Old 05-11-2009, 02:29 PM
fkemmerer's Avatar
Thanks Chris. I am planning on repainting mine with Ranger Tire paint. Does anyone know if this paint can be thinned and sprayed with an air brush? If so, what is the recipe for doing this.
- Fred
Old 05-11-2009, 02:30 PM
fkemmerer's Avatar
chris
Chris,
Do you have any idea if these stencils match the outlines on the currently avaiable Goodyear Billboards?
- Fred
Old 05-12-2009, 12:13 PM
- Fred
I had a hard time cleaning the brush.
- Paint thinner - no
- Acetone - Not thin paint readily, although enough to clean the brush
I asked Ranger's tech support on an email; no reply. Must be a secret.
Old 05-12-2009, 03:35 PM
Isopropyl alcohol.
Chas.
Old 05-26-2009, 10:35 PM
fkemmerer's Avatar
My wife and I got round to repainting the letters on our Goodyear Billboard tires. From other postings on this board, I've seen many different approaches to doing this which helped us alot in finding a technique to do our tires. Here's what we did:
1) We cleaned all of the original paint off the tires with solvent (we used lacquer thinner with gentle rubbing).
2) We outlined the letters with a white tire pen to get crisp edges around the letters (we used a Medium Tip Markal Valve Action Paint Marker).
3) Next we applied 2 coats of slightly thinned Ranger Tire Paint. We used isopropyl alcohol as the thinner. The paint was applied with a 3/16" artist's brush.
4) Finally, we applied 2 more coats of more heavily thinned Ranger Tire Paint. The thinning of the paint for the final coats was such that it flowed out with almost no visible brush strokes.
The following is a picture of the final result:
This entire process took about 8 hours to complete for all 4 tires - quite a bit of time but worth it I think. We are giving the paint a few days to dry and then I'm going to put the Billboards back on the car. I will post some shots of the final result over the weekend.
- Fred
Old 05-27-2009, 04:23 AM
FUNFER2's Avatar
What a fantastic job that you and your better half did, you should be very proud of yourselves !
Please climb aboard your Leir Jet and come do mine !
I'll have a box of wine waiting for you.
Kevin
Old 05-27-2009, 04:47 AM
FUNFER2's Avatar
Question's- when I ordered my Ranger paint, they said not to thin the paint. Ranger Tire Paint.
What was your mixture amount ?
Also, where did you get that specific paint pen ?
I assume there was no bad reaction between the two paints.
Kevin
Old 05-27-2009, 05:30 AM
fkemmerer's Avatar
Kevin
If you google the name of the pens you should not have any trouble finding a source for the pens. There was no reaction between the pens and the ranger paint. I found the paint too thick to go on using a brush without showing the brush strokes so I thinned it. This is probably why I needed four coats. Just thin it a little bit for the first two coats and then more on the final ones. Thin just enough on the last coat so you hardly see the brush stokes. Sorry but I did not keep track of the exact mix.
- Fred
Old 05-27-2009, 07:17 AM
Banned
Right click...save as... (thumbs up)
-Dean
Old 05-30-2009, 11:22 AM
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Roger Paint - new Billboards - what a complete hassle - I'd say one person - 20 hours at least and in the end, you may not be a happy camper. As noted above - a great tip is to outline the inside of the ridges first - I didn't do that, so a lot of extra work was needed. Of course, the perfect look would be the not end up with paint on the inside of the ridges, on the ridges or, of course, outside the ridges. The problem with Rogers paint, in my view, is that it readily comes off in sheets - in other words, entire sections of paint easily peel off when one just wants to clean up a really small section. Also, it bubbles - sort of like it's not actually sticking to the rubber. If I'm doing something wrong to casue this - please let me know.
Bottomline - what a huge hassle - I love the look of the Billboards and if this doesn't come out right I'll probably go with no paint. I'd say this - if you are a really anal Cobra owner - one that wants a perfect look - don't even attempt painting the letters on Billboards - it will not turn out perfectly in your lifetime.
Old 05-30-2009, 04:25 PM
MaSnaka's Avatar
I think Fred and his wife should apply for jobs at Goodyear and train those people on painting tires. They look too good. I hope that paint stays looking good, I guess time will tell.
Old 05-31-2009, 12:11 PM
fkemmerer's Avatar
Here is a picture of the freshly repainted Goodyear Billboards on our ERA Cobra. These tires just seem to look right on these cars.
We've put about 200 miles on the car with the tires installed and we have not had any problems with the paint chipping or bubbling. I think that cleaning the tires with lacquer thinner first was probably key as it most likely got all of the silcone from previous applications of tire dressing off the tires. We have been using a natural tire cleaning and treatment product from Zymol to clean and detail the newly painted tires and it seems to work well without damaging the paint.
- Fred
Old 06-10-2009, 08:10 AM
Fred,
You certainly set the standard for refinishing these tires!!
Nice work; beautiful roadster!!
Old 06-10-2009, 10:05 AM
FUNFER2's Avatar
Looks great !
That's what I exactly what I want. Nice & white letters with dressing that's not too shinny. In the photo, did you treat the treads too ?
I hope mine comes out that good.
My buddy with the chassis dyno recommends to wait to paint my billboards until after the last run, for the magazine saying, it's hard on bias ply tires.
Kevin
Old 06-10-2009, 10:11 AM
FUNFER2's Avatar
Fred- Griot's garage has a gel product that is applied one per year and has the "New Tire" look, not too shinny like yours. I'm concerned about spraying the typicial dressing on the white letters and having problems.
"natural tire cleaning and treatment product from Zymol to clean and detail the newly painted tires and it seems to work well without damaging the paint"
Is this the product ?
$28 (ouch)
Kevin
Old 06-11-2009, 10:36 AM
fkemmerer's Avatar
$28 (ouch)
Hi Kevin,
Yes, the Zymol product that you mention is what we are using. I would guess that 1 bottle lasts a long time.
- Fred
