Old 09-07-2010, 06:48 PM
Default GM Synchromesh, which one?
Gang,
Changing the fluid in my TremecTKO.
Went by the GM dealer and got three quarts of:
-GM Synchromesh Trans Fluid "FRICTION MODIFIED" #12377916
went home and looked at the OLD bottle of GM fluid:
-GM Synchromesh Trans Fluid #123455349
The TREMEC manual specifies the standard fluid #123455349 for the TKO, not the "Friction Modified". I am guessing the "Friction Modified" fluid is too slippery to drive the synchros in this ...or is the other way around?
Anyone know the specific application of the "Friction Modified" and what the characteristics of the fluid are? More or less slippery?
Pete
ERA 289 #2027
Old 09-07-2010, 06:56 PM
Hi Pete,
The GM# 12345349 is the correct number. Just return the ones you have for the correct lubricant.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 09-07-2010, 09:23 PM
Default what I thought...
Mike,
Thanks for the guidance...I will take it back and hopefully they have the correct fluid...local Chevy was out, sent me to the Cadillac dealer. They had this stuff but the parts guy at either place didn't know anything about it much less for a "Tremec TKO"...
Just out of curiousity is the "Friction Modifier" flluid more or less slippery? and which trans if it intended for?
Thinking about limited slip diffs, where the "friction modifier" or additive, as I understand it, increases friction so the clutches don't slip...different design synchros may need more or less friction...so which way does the modifier take the fluid?
Pete
ERA 289 #2027
Old 09-07-2010, 11:25 PM
Rick Parker's Avatar
Suffice to say if you found it at the Cad dealer that it was intended for the CTS V which is quite a ride in its own right. I think some of them had Gertag transmissions.
Old 09-08-2010, 06:57 AM
Much Kudo's to YOU!!!!! Excellent job researching and not creating a problem. Most would have relied on the dumbsheet behind the counter for advice and dumped in the transmission.
Old 12-31-2011, 09:53 PM
Cobra Make, Engine: Superformance aluminum427
Default Syncromesh fluid
It certainly is not cheap, 3 quarts cost me about 55.00$. the part stores carry syncromesh by Pennzoil, its about half the cost of GM. Flip
Old 12-31-2011, 11:31 PM
DanMartin's Avatar
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
http://www.pennzoil.com/documents/Sy...ns%20Fluid.pdf
The Pennzoil stuff is direct replacement for the GM fluid, per that data sheet....
Old 01-01-2012, 11:10 AM
Tony Ripepi's Avatar
Cobra Make, Engine: TBD
I switched to the Redline equivalent after running the GM for ten years/18000 miles and it is much smoother.
TR
