SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 10-07-2010, 05:28 PM
IMLost's Avatar
Cobra Make, Engine: BDR #178 United Speed World Special
Default Top bolt lenngth
I,m putting a T5 into a 302 block. My bell housing measures 1" at the bolt hole location. If I use a 2" long bolt it bottoms out before it is tight. Should I have a flat and lock washer or any washers at all?
I'm afraid if I go to a 1 1/2 " bolt I won't have enough bite into the block.
Should the bolts have thread lube or locktite? Looking for opinions.
Thanks all.
Doing and driving what other people dream about!
Old 10-07-2010, 06:03 PM
Screw the 2" bolt into your block and measure how much distance there is between the block and the underside of the bolt head. I always use a washer and lock washer. You can get bolts in I believe 1/8" increments at your local hardware store.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 10-07-2010, 06:12 PM
CHANMADD's Avatar
I'll bet if you put a flat washer and a spring washer it will be perfect.
Old 10-07-2010, 06:21 PM
Rick Parker's Avatar
Use a 1.75 long bolt and a lockwasher, no locktite, or as an alternative an AN washer and a little locktite. Use quality bolts Grade 5 (3 mark) or Grade 8 (5 mark) hardware.
Rick
Old 10-07-2010, 08:27 PM
IMLost's Avatar
Thanks all. Already have grade 8. I think in my circumstance the 2 washer set up is the answer. I started with what tcrist said and that's how I came up with exacts. I" exposed with 1" of housing after the bolt finished out. I was leaning to the flat and lock set up, and now that's what I'll go with.
