Like Tree1Likes
  • 1 Post By xb-60
Old 01-22-2015, 01:54 PM
xb-60's Avatar
Default Toploader ID
Need help. The tag with RUG-** or HEH-** is missing.
Here's the main case ID:
Is this a CR or a WR box?
Is there a cross reference table somewhere that relates RUG/HEH ID with case ID? Can't find it on DK's site.
Glen
Old 01-22-2015, 03:52 PM
Fast289's Avatar
Cobra Make, Engine: FFR 289 FIA 347 Stroker
That's just a serial number. From all the research I have been doing on my top loader, you might be out of luck. I hope I am wrong.
Dave from Chandler.
Old 01-22-2015, 03:58 PM
DanEC's Avatar
Glen
There are some main case part numbers cross referenced here but it's far from complete.
Toploader id
However, based on the 7006 - W markings it looks like it could line up with a CR box. A lot of things get messed with over 50 years however so witiout opening it up or counting revolutions of input to output in 1rst gear you can't be sure.
ERA 782 Running
Old 01-22-2015, 04:24 PM
xb-60's Avatar
Thanks.
Looks like the C8AR-7006 main case was used for both CR and WR.
Read somewhere that the "W1" on the casting indicates a CR and "W2" indicates WR. Is this familiar to anyone?
Glen
Old 01-22-2015, 04:46 PM
Bernica's Avatar
Senior CC Premier Member
Here is a tip from old school docs I have and quoting:
"Pull the front bearing retaining collar off of the front of your Top Loader. If you see a machine mark on the input shaft, it should be a wide ratio transmission."
I have seen them and it looks like they just turned a groove in them to ID the trans, but that was a long time ago.
You may want to just call Dave Kee. He will help you.
Good luck!
Old 01-22-2015, 04:49 PM
Dwight's Avatar
Smile
I guess you have looked at this chart
Toploader ID Chart
Old 01-22-2015, 05:03 PM
xb-60's Avatar
Bernica and Dwight, it's a box I'm thinking of buying, so I'm trying to ID it by remote control. Seems if the tag with the RUG or HEH number is gone, the only way to check if CR or WR is to count the turns of both shafts in first gear. That's what I'm asking the guy to do now.
Glen
Old 01-22-2015, 06:24 PM
Bernica's Avatar
xb-60: I may be wrong, but I think they all used the same cases of "boxes".
Old 01-22-2015, 06:55 PM
xb-60's Avatar
Yes, I agree. It would seem that the C4 in C4AR indicates a 1964 build, C6 is 1966 C8 1968 and D2 is a '72. It doesn't indicate what's inside the gearbox.
Without the RUG/HEH tag, the box becomes somewhat of an orphan.
Glen
Old 01-28-2015, 03:09 PM
xb-60's Avatar
Update....
Comparing turns of input with output turns in first gear, it's a WR, which is what I want.
So... WR, correct tailhousing, shifter included, known history. I bought it.
Glen
750hp likes this.
