Old 06-12-2015, 05:46 PM
Cobra Make, Engine: Factory Five, 390FE
Default Can any one help?
I am trying to decide which Hurst installation kit I will need for the following build.
Factory Five Mark4, FE Big Block, Toploader transmission (case RUG D2, tail piece C70) and a Hurst Pro/Comp shifter. I want the shifter to come up so that I can use a replica 427 shifter.
Does anyone have experience with this or should I just wait and install the powertrain and determine what I need then?
Paul
Old 06-13-2015, 04:33 AM
DanEC's Avatar
That appears to be a late 60s Fairlane or Falcon toploader but I'm not sure of its tail housing length - probably the mid-length with an overall length of 25.5 inches. But from the pictures on this site for that model, it looks like the shifter mounts are mid-point on the tail housing.
Toploader id
I suspect you will need a mount that moves the shifter to the rear end of the tail housing to fairly accurately reflect the original 427 mount. But, I'm not sure as it can depend on how far back the engine is mounted, etc. You are probably safest to wait until the drivetrain is in the car, but you could mock up the drivetrain and determine where the shifter mounts are in relation to the engine mounts (or transmission mount and get a pretty good idea as to where it will fall on the tunnel.
ERA 782 Running
