January 2026
| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
2Likes
2
Post By Dimis
07-06-2016, 08:10 PM
Club Cobra Member
TX
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
which transmission fluid for a toploader
My old notes say 75-90, but what say ye? Synthetic or not? Street driven not tracked. thanx steve
steve meltzer
"I may be wrong, but I'm never in doubt"
Advertising
07-06-2016, 09:19 PM
CA
Phil
http://www.uniquecobra.com/
07-07-2016, 12:21 AM
Vic
I hear Bernica, who is a big fan of the toploader uses this stuff.
07-07-2016, 04:44 AM
NY
Do not mess with it, good old 80-90 gear oil is what it needs.
07-07-2016, 07:53 AM
AR
GL-4 is normally recommended for older transmissions but most will agree that GL-5 works OK. There's an argument that GL-5 corrodes brass but a lot of people disagree it's an issue.
I would stay away from synthetic. Some say it will defeat the action of the syncros. I ran synthetic in a Muncie for about 15 years without issue, but recently changed it out to GL-4 which can be obtained at NAPA. Interestingly, the only thing I noticed different about synthetic was that the Muncie aluminum case took on an oily sheen appearance (but dry) like the case was permeated through and through with it.
07-07-2016, 02:44 PM
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
80 gear oil. NO EP ( extreme pressure ) derivatives.
Jac Mac
07-07-2016, 05:43 PM
Club Cobra Member
TX
thanx. think i'll get a nice robust zinfandel for that cheese. s
steve meltzer
07-07-2016, 06:25 PM
Senior CC Premier Member
CA
07-07-2016, 06:30 PM
CA
I forgot to add that you should put a stick of butter in as well! JK!
07-07-2016, 07:16 PM
NH
