SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 08-12-2003, 12:40 PM
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Default What are my options for a Hydraulic Slave Cylinder for a T-5
I am looking for a hydraulic slave cylinder and/or mounting bracket that will work on my T-5 transmission. The setup from Autoworks is kind of pricey, and I do not want a hyraulic throwout bearing setup like McCleod offers. Are there any other hydraulic slave cylinder options that will work with the T-5. I already have the Girlind?? 3/4 Master cylinder sooo, I just need the slave now. Preferrably something that will bolt right up to the tranny or bellhousing.
Thanks
Old 08-12-2003, 02:21 PM
Mr.Fixit's Avatar
Custom make your braket to mount it with a 6" section of 2" wide angle iron. Then, go through the catalog at the parts store with all the factory replacement slave cyls for newer cars, find one with the bore and length you need. It might be an odd one, for a ford probe or something. You will need to do a little math to calculate volumes and such.
Old 08-25-2003, 08:06 PM
Cobra Make, Engine: Sold my FIA Cobra to MrMustang
Willwood makes a pull type that often works with the Mustang bellhousing.
Adam Crabtree
www.sportscarguyspeaks.com
Old 08-25-2003, 08:21 PM
bmalone's Avatar
Here's what I did: custom made a bracket from angle-iron just as Mr. Fixit says. Then purchased a CNC push-type unit. There are many distributors for CNC hydraulic products. Here in SoCal, the Off Road Warehouse (ORW) carries them--they are popular with the off-road and street rod crowd. They are inexpensive at $55 and it works much better then the Girling it replaced.
Bill Malone
Gashole
CSX4786
Old 08-25-2003, 08:37 PM
decooney's Avatar
... you can also look at some of the older BMW slaves used. Go to a junkyard to get some ideas on sizes and shapes, then you can buy one or rebuild one to customize and try from there...
Duane
Old 08-31-2003, 03:25 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
This may sound like a silly question, but why do you want hydraulic, rather than cable. The T5 bellhousing is made for a cable pull. Cables, particularly the aftermarket units like BBK are frictionless and trouble/maintenance free. You need to modify the cable quadrant to fit on the Cobra clutch pedal. And you can do final adjustment, and clutch wear adjustments from the firewall.
