Old 08-26-2003, 10:52 AM
Russ Dickey's Avatar
Cobra Make, Engine: Unique Motorcars 289 FIA
Default Correct Shifter question
My 289FIA has a Tremec 3550 with a Hurst shifter. It is functional, but is too tall. After being in Monterey and seeing all the real 289 Cobra's and their shorter shifters (with T-bar Handles), I think I'd like to have one a little more original-looking. Does anyone offer the 289-style shorter shifter for the Tremec, or am I going to have to get the cutting torch out???
Russ
Old 08-26-2003, 11:09 AM
jams's Avatar
Cobra Make, Engine: B & B
I had the same problem. I cut it down about 1-1/2 and welded it back together. Now I'm Happy. There migh be other shifters out there but after I spent about 60 buck on the one I had I was not about to buy another one.
Good luck
Old 08-26-2003, 11:21 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Check out konaracing.com, it might work for you..>Earl
Old 08-26-2003, 11:25 AM
Thanks for the referral. I checked out the website, but I should have clarified that I want the straight-style short shifter, and Kona only offers the Mustang-style bent-shaft.
Old 08-31-2003, 05:08 PM
Russ - My 289 shifter is cut and welded as per Jams Suggestion, the rubber boot easily covers the weld.
Andy
Promoting 289's in a country awash with 427's
Old 08-31-2003, 05:27 PM
Cobra Make, Engine: Heritage body, built the rest..460 Toploader..9"
I have a short t-shifter straight that I'm not using...
6year Heritage A&F
1969 Hurst SC/Rambler(only 1,512 made) in the middle of restoration.
