SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 01-05-2004, 03:42 PM
Question Ford TopLoader for a bigblock behind a small block
Hi all,
First thanks to all you fellow Cobra guys that use these forums. The discussions here have help me out time and again.
I purchased a 351W with a Ford Top Loader attached to it that I put in my Cobra. I ran it for about a year now.
I have started to replace the Clutch, Pressure Plate and TOB. While replacing all this I found that the "stock" Pilot Bushing was shorter that the one I pulled out by about 1/8".
The tranny appears to be a Top Loader for a Ford Fairlane with a 390 engine(Tag #HEH CL 015155.) The bellhousing was changed to fit the small block but the input shaft nose is only 3/4".
I have read that this can possibly damage the tranny. What should I do in this situation?
Any info is appreciated,
Rick
Old 01-05-2004, 04:00 PM
Cobra Make, Engine: Johnspeed,408W,Tremec 600 roadrace, Liquid Yellow w/Black stripes
With 1/8 inch difference, I'll think no big deal. But go to a parts house(Napa) and match up your old one. Better yet get a bearing instead of a bushing. The bushing/bearing just supports the imput shaft, at the crank end.
Old 01-07-2004, 06:40 PM
Rick,
The tip of the input shaft needs to be 1 1/8" long behind a small block. If you run the shorter 390 input it will not reach into the bushing and cause front bearing failure in the transmission.
Old 01-08-2004, 05:14 PM
Hi David,
Would a longer pilot bushing be sufficient or is that inviting failure? I could have one made it this would take care of the problem.
Any information is appreciated.
Rick
Old 01-08-2004, 06:37 PM
All of the extended pilot bushings I have seen have not lasted very long. They wallow out and then it is a disaster for the transmission.
