SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 02-01-2004, 12:29 PM
Cobra Make, Engine: Kirkham Body Factory Five frame, 1966 427 center oiler
Default 427 Trans id
HI , I am currently in the process of building a cobra replica.
I need some help with the transmission. I am trying to locate the correct original transmission. Iknow that it's a ford toploader, But I have not been able to find anywhere what would be the Id number/letters for it . any help would be great Ed
Old 03-04-2004, 06:01 PM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
ED B,
Most all the COBRAs carried ID tags of HEH-GXX, HEH-PXX, HEH-BRXX, HEH-TXX, HEH-BXXX and a few others.
The 427/427 COBRAs used 24" transmissions, while all full size cars used the 27" box. The 1964 toploader used a small 4 hole maincase with the small O.D. bearing retainer.
The tail housing for the 427 Cobra style shifters are available for toploaders with the following ID: C60.
There were over 130 models of the toploader, Dan Williams or David McKee can build you one cheaper n better than you'll ever find at swap meets.
grumpy
Old 03-04-2004, 06:43 PM
Ibr8k4vetts's Avatar
what grumpy said is correct. Mike
Mike Z
Old 03-08-2004, 06:02 PM
HEH BY would be the most common correct tag. Very hard to find.
http://www.davidkeetoploaders.com/idchart1.htm
