Old 06-28-2004, 11:51 AM
priobe's Avatar
Default What clutch to use for a FE and Toploader
I am about to drop my motor and transmission on to the chassis. I would like to know what clutch system should I go with?
I have a 427 FE with a toploader transmission. Motor puts out about 550 hp.
Old 06-28-2004, 04:45 PM
Ibr8k4vetts's Avatar
http://www.4speedtoploaders.com/
Mike Z
Old 06-28-2004, 07:14 PM
decooney's Avatar
I ran the McLeod 12" pressure plate and disc setup including the flywheel from David Kee too. So far so good.
Duane
Old 06-28-2004, 09:32 PM
I'm having the McLeod 12" p plate and disc installed this week. It will replace an 11.5" unit. Hard to tame 600 plus horse, I need the biggest clutch I can get but DON'T want to go to a "raceing" style clutch. I do drive the street after all.
Duane, anything special about that flywheel? Mine is from a 428 and I plan to have it surfaced and use again. New pilot bushing and throw out bearing while I'm in there.
Old 06-29-2004, 05:00 AM
larryar's Avatar
Cobra Make, Engine: CACC Member. Power Performance, 2X4's, 428
I use a Center Force and a hydraulic throwout bearing.
Big Blocks Rock!
Old 06-29-2004, 10:07 AM
priobe's Avatar
Hey Larry,
I was thinking about a Center Force and called them up.
They are recommending a Center Force 2
Part # CFT- 360033
Part# CFT- 281226
I also wanted to go with a Hydralic Throw out Bearing like you mentioned. Any ideas where the best place to get the product.
Thanks for the info.
Old 06-29-2004, 10:50 AM
larryar's Avatar
Priobe, when I get home from work I'll send you the part numbers.
Big Blocks Rock!
Old 06-29-2004, 11:15 AM
priobe's Avatar
Thanks Larry I sent you an email with some info
THANKS AGAIN
Old 06-29-2004, 11:18 AM
I,ve run the stock replacement Borg-Warner for many years,no failure and lots of power.
