SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 07-14-2004, 08:57 PM
Default Hyd throwout bearing or std bearing
I spoke to George Gessford (Gessford Automotive) he is recommending the standard throwout bearing not the Hyd unit.
What do the members of club cobra think?
Thank You
Old 07-15-2004, 02:12 AM
Cobra Make, Engine: Antique & Collectible 351 windsor bored and stroked tko tremec
Hi greg im using a standard throw out bearing with hyd slave cylinder. also it is much easier for repair internal t/o bearing you have to remove tranny for repair.i mounted a bracket on two of the tranny mounting boltsand fastened slave cyl to it and it works fine. just my .02 good luck Neil
Old 07-15-2004, 05:20 AM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Greg, I have a hyd. throwout bearing only because I have no room for a fork with my Lakewood bellhousing. If you can, do what Neil has done with an external slave unit, he's right.
Tim
" It ain't no big deal"
Old 07-16-2004, 10:30 AM
Roscoe's Avatar
I've got over 20K on my Tilton Hydraulic Bearing and it is the same as the first day I pushed in the clutch.
It's all in the correct installation.
Roscoe
Roscoe
Old 07-16-2004, 12:51 PM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I use a standard TO bearing but use a late Mustang clutch cable with a homemade clutch quadrant. The OEM quadrant just didn;t pull enough cable per inch of pedal travel so I made my own adding 1/8" to the radius. It works very smoothly and with a diaphragm pressure plate is not uncomfortable to use. I agree with Roscoe that it is all in careful and proper installation but I am a firm believer in keeping things simple. That's why I opted for the cable setup. I use a Lakewood blowshield and just had to relocate the pivot ball to the passenger side of the housing which was no biggie.
Rupert Hartmann
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
