05-06-2005, 10:56 AM
T56 Problems???
I own a hot rod shop, and am wanting use a T56 in a '51 Ford Shoebox I'm building. I called Keisler to order one, and the rep there told me the T56 was junk, and that putting it behind a 5.4L DOHC Nav motor was not a good idea. Also, the rep at Victor Ford (my Motorsports dealer) said something simular. That the 300+ HP from the Nav would eat the T56. Both said TKO was a better option. My argument is that the Cobra(2003), Viper, LS1, WS6, Vanquish all use the T56. So how are these companies not being inundated with service warrenty work if the T56 is junk. Have any of you guys experiance poor performance or constant breakage with this tranny?
Kevin Tully
Owner
Hot Rod Chassis & Cycle
(630)-930-7078
05-06-2005, 12:00 PM
Cobra Make, Engine: BDR 930, 427 Windsor T56
I've never had a problem with the T-56. I put one in a 92 Mustang with 450 rwhp. I had an 03 Cobra with one. It is basically the same tranny in the C-5 Vette too and I have one of those now.
The Viper spec T-56 is built a bit stouter then the standard Ford version. You can get a Viper spec T-56 for a Ford.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
05-06-2005, 01:41 PM
Thanks for the input. I didn't think they could be that junk with so many manufacturers using it. Any body else?
05-06-2005, 02:08 PM
WA
Cobra Make, Engine: Superformance Brock Coupe
T56 Tremec
The T56 is actually a more modern design than the earlier TKs, which use older brass synchro technology. According to the tech guys at Rockland Standard Gear in NY, where I purchaesd my T56, the clearances are much tighter and more critical in the T56, so you cannot run heavier oil. (Some people have done this as they've had issues with gear whine in the upper ratios, but that is not the fix! Get the transmission "blueprinted" and it'll run silent. Rockland has data on more than 1000 hp being run through the T56s, so they are very strong. The advantage of the six speed on the road is really appreciated. If I were buildiing a car just for track work I might consider the TK as it is lighter, less expensive and shorter, so there is less drive-shaft angularity in a chassis where the engine sits rearward. T56s are excellent transmissions...you just have to make sure the set up is right. Badger
05-06-2005, 02:11 PM
WA
T56 Tremec
The T56 is actually a more modern design than the earlier TKs, which use older brass synchro technology. According to the tech guys at Rockland Standard Gear in NY, where I purchaesd my T56, the clearances are much tighter and more critical in the T56, so you cannot run heavier oil. (Some people have done this as they've had issues with gear whine in the upper ratios, but that is not the fix!) Get the transmission "blueprinted" and it'll run silent. Rockland has data on more than 1000 hp being run through the T56s, so they are very strong. The advantage of the six speed on the road is really appreciated. If I were buildiing a car just for track work I might consider the TK as it is lighter, less expensive and shorter, so there is less drive-shaft angularity in a chassis where the engine sits rearward. T56s are excellent transmissions...you just have to make sure the set up is right. Badger
06-16-2005, 11:07 AM
Re: T56 Problems???
Kevin Tully
Owner
(630)-930-7078
Those guys must be on heroin
06-16-2005, 03:13 PM
Vic
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Great Box
Kevin have a look unter the Australian Cobra Club forum for Garrett's gearbox - The Autopsy
Ive run a T56 for the past 18 months and it finaly let go only a little though.
With 550HP a the rear wheels on further investigation Aussie Mike has found the problem and the box is on the mend with the new parts from good old USA.
Look at the thread, also if you look at my picks too you will see that Aussie mike has also moved my shifter stick up further, this may suit your application to in a ROD. More pic's look at Auusie Mikes pic's too
Regards Garrett
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
06-23-2005, 07:13 PM
Cobra Make, Engine: '99 Blk V8 32V Coupe SVT
Re: Re: T56 Problems???
No kidding, go to a REAL perf. shop where they actually G/A/S about your ride. That's nuts what they're saying, no offense. Just my opinion, be careful.
"Beat one...you're good, Beat many...you're great, Beat them all...you're a GOD!"
06-26-2005, 02:32 AM
T56
Doesnt the Viper T56 have a 30 spline mainshaft and other improvements over the standard non Viper T56 of 27 spline?
Do any of you guys run a trans cooler?
I intend on doing short type sprint races of -
5 laps of a 3mile course!
A J. Newton
The 1960's rocked!
07-16-2005, 09:02 AM
Cobra Make, Engine: Hi Tech Cobra Contemporary Cobra
My 04 GTO is in the shop now with tranny problems. 1st they didnt torque down the clutch properly at the factory and it came loose. Ive always had problems in cold weather shifter 1-2 or downshifting 3or4-2. Ive got a feeling this might be the tip of the iceberg. Im building a cobra now and if I go with anything other than a toploader I think I will use a richmond 6 spd.
'"An appeal to arms and the God of hosts is all that is left us. But we shall not fight our battle alone. There
is a just God that presides over the destinies of nations. The battle sir, is not to the strong alone. Is life so dear or peace so sweet as to be purchased at the price of chains and slavery? Forbid it almighty God. I know not what course others may take, but as for me, give me liberty, or give me death."' Patrick Henry.
