Old 05-10-2005, 11:46 PM
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
Default Need clutch selection advice
I am putting together a drivetrain for my BDR roller. I have a 351w stroked to 427 c.i. and expect it to put out around 520 hp and 500 lb-ft. I have the new Tremec TKO600 transmission, and I am trying to select the components to go between them. I've pretty much decided on a McLeod safety bellhousing, but I don't know which clutch to get. Ford Motorsports has something they call the King Cobra, part number M-7563-C302. Does anyone know anything about it? Is it a good choice? They also have a clutch disk that they say will work with the new Tremec input shaft. (It has 26 splines instead of the usual 10.) Again, anyone have any opinions?
Finally, if I go with those, what release fork and throwout bearing should I use?
TIA
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
Old 05-12-2005, 11:30 AM
Default Clutch
I recommend you look at McLeod, they have very high quality clutch kits. I one we sell a lot (Chevy's only) is their dual performance (street/strip) 12" clutch. Very good quality and performance.
Give McLeod a call at 714-630-2764. If you were looking for a Chevy clutch we could help you out but sounds like you need Ford.
Hope it helps
Scott
www.ClassicChevy5Speed.com
PH: 760-230-2045
Old 05-12-2005, 11:38 AM
Thanks Scott. I went with the McLeod bellhousing, fork, pivot stud, and throwout bearing. Then I bought the Ford cllutch disk and pressure plate. Hope they all fit together!
'round Midnight
A new vibration
I'm a sensation!
