Old 05-27-2005, 08:49 PM
Default T5 Transmission gear ratios?
Anybody please tell me the gear ratios in a regular T5 transmission?
Thanks in advance!
Edley, The Cobra Rogue!
Old 05-27-2005, 09:13 PM
Buzz's Avatar
Edley, go here:
http://www.fordmuscle.com/archives/2...p/index2.shtml
Tropical Buzz
Old 05-28-2005, 09:48 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
The numbers on my T-5 are: 13-52-066-908?
The only thing that seems to match the chart is the 13-52??
Any suggestions, T. Buzz??
Old 05-28-2005, 10:52 AM
Buzz's Avatar
Earl, 13-52-065 is from a 1984 Mustang/Capri 5.0 V8
and..13-52-067 is from a 1984 SVO w/Hurst 2.3EFI Turbo
066 shows "don't read casting number"
I guess you can safely bet it's from a '84 Ford Mustang of some type or another. You can do some digging at:
http://www.5speeds.com/t5/index.html
Good luck.
Tropical Buzz
Old 05-28-2005, 01:51 PM
Send a message via AIM to Chris Robinson Send a message via Yahoo to Chris Robinson
http://www.ddperformance.com/Trans%20ID%20chart.htm
Old 05-28-2005, 06:42 PM
Ouch Ouch Hot Sand
I can not find the 066 ID anywhere or a reference to it other than the one Buzz indicated??????????????????
Old 05-28-2005, 07:53 PM
Buzz's Avatar
Earl, did you get that number off of the stamped tin tag or did you read it off a casting. If it's a casting, it won't be of any help. Gotta be the number on the tag. I suspect 066 just a casting I.D. number.
Tropical Buzz
Old 05-28-2005, 08:12 PM
Ouch Ouch Hot Sand
Buzz, there is no tin tag. The number I read is cast into the box where the shifter is mounted. I did find the following sequence cast into the main body of the T5; 13-52-065-904. A little different than the others, but again, No tin tag...........Thanks, Earl
