SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 03-17-2006, 09:14 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Default wires on new T-5z ?
just got a T-5 z from summit and it has three places for wires ?One set drivers side front has a pigtail ,one drivers side middle has two sockets and two wires off the speedo cable. What do all these wires do?
the older i get the faster i was.
Old 03-17-2006, 09:15 AM
CobraEd's Avatar
Ignition kill for when not in neutral and backup lights
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 03-17-2006, 09:39 AM
pmfranke's Avatar
which one is which and speedo wires do what?
Old 03-17-2006, 10:06 AM
The wires off the speedo connection are either for an electronic speedometer or for a fuel injected car with a computer for input. The one on the lowerr driver side is the back up light connection. The ones on the top of the shifter fork case is for the neutral disconnect switch.
Old 03-19-2006, 06:51 PM
pmfranke's Avatar
thanks,all. three peaks how is the t-5 holding up under the stroker and what rear end ratio did you use?
