Old 04-07-2006, 08:40 AM
STEVE POTTS's Avatar
Cobra Make, Engine: Midstates, 427FE stroked to 482CI
Default clutch disc recommendation tko 600/ 486CI FE
Care to share any good experiences with a particular clutch disc? I plan to run an 11" disc and steel flywheel behind a 486 ford Fe. There are so many clutch discs on the market...its overwhelming...
Old 04-07-2006, 10:39 AM
Tony Ripepi's Avatar
Cobra Make, Engine: TBD
Hi Steve,
Call "Red" at McLeod......tell him what you have and let the experts give you a recommendation. Typically when you say 11" versus any other dimension you are going by the seat of your pants. Talk to people that can give you a recommendation for Clutch, pressure plate, bell housing, throw out bearing , internal/external actuator etc. a complete system.
http://www.mcleodind.com/
Good Luck,
Tony R.
Old 04-07-2006, 10:48 AM
I've had good luck with the Hays S/S clutch kit.....
I think I'm going to try the Zoom clutch kit next time...they have a street/strip setup (11") in Summit Racing for just under $200.
Old 04-08-2006, 11:38 AM
Default parts
Tony,
I talked to "RED". He recommended a 12" clutch disc, organic on one side and kevlar/asbestos on the other and a 2400 lb diaphragm style pressure plate. The goodies are on their way from sumitt. Thanks for the contact info...
Old 04-09-2006, 08:32 PM
Hi Steve,
Glad that worked out.....he is a great guy and he has helped me many times with his wisdom,competitive knowledge, technical expertise and willingness to work deep into the details.
Tony R.
Old 04-10-2006, 04:10 AM
Steve, did you order your flywheel through him as well? I've noticed that many FE flywheels for cars only have patterns for 11/11.5" setups. My new Fidanza aluminum flywheel only has that pattern....
Old 04-10-2006, 06:16 AM
Clois Harlan's Avatar
Steve,
I am running a kevlar clutch and I really like it so far. In the past I have ran both the Hays and the Zoom clutch and I think they are both good applications for street/strip.
Clois
"Let's roll"
"Be part of Something Good
Old 04-10-2006, 09:37 AM
Blykins,
The Mcleod parts I ordered are as follows:
28 pound Steel Flywheel #463215
Pressure plate #360821
Disc 260873R
Mcleod tells me that the bolt pattern on the flywheel/pressure plate is the 11.5" pattern but the 12" clutch disc fits within the bolt pattern.
Also, the R after the disc # means "reverse hub". I am running a TKO 600 which has the 1 1/8 x 26 spline input shaft...apparently this is a standard chevy spline pattern and diameter. But the hub needs to be reverse oriented for some reason.
I ordered the parts through summit
Steve
Old 04-10-2006, 09:38 AM
So you can run a 12" disc on an 11.5" pressure plate? I didn't know that. Is that true for almost any size? i.e. can you run a 11.5" disc with an 11" pressure plate?
Old 04-10-2006, 09:54 AM
Blykins,
Talk to Red the use of a 11.5" with a 11" plate will be determined by torque of the engine, transimission type, type of pressure plate and several other variables that I probably know nothing about.
The guys who know are the people that are hip deep in the details of these applications every day. The reality is that you need to look at the space from end of the engine shaft and the yoke at end of the drive shaft as a complete system and get the right components in that system to meet the needs of the application.
Tony R.
Old 05-07-2006, 06:08 PM
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
Default Clutch
I am running that clutch combo behind my 489 and love it. No chatter, easy on the leg
BTW for Blykins, ALL 12 inchers dont fit 11.5 inch flywheels. This 12 incher uses a cover that is drilled to fit an 11.5 inch Ford clutch
Its a super setup for CJ cars and any Tremec equipped FE or 385 series Ford
