SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-22-2006, 12:19 AM
Cobra Make, Engine: DRB - 302, T5, VN Rear
Default Which oil for my early T5 - do I use 70w gear oil ?
Hi all,
Just wondering what oil to use in my T5.
The ID tag on my T5 is 1352-034, which shows it is from a Ford 1983 SVO Mustang 5.0 V8. Am I correct to use 70w gear oil and not auto trans fluid as used in the later units ? Found this at http://www.moderndriveline.com/Techn...t5_history.htm
Thanks,
Dan
Old 11-22-2006, 06:16 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
It will be interesting to hear, but I was under the impression they were all ATF, unlike the website you posted. I also didn't think that the World Class tranny came out until later in the 80s. It will be interesting to see what the T-5 gurus say. I will check my '83 factory manual, though.
WDZ
Old 11-24-2006, 08:12 AM
Jimi G's Avatar
T5's take ATF, install ATF and you will be fine. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 11-24-2006, 09:05 AM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
GEEZ, I don't know what you have there. I checked my T-5 WC ID chart and the lowest number listed was 1352-114. Sure sounds like you have a NWC tranny there. If I was in your shoes I would either try to ID the exact vehicle the tranny came from and follow the OEM recommendations for gear oil or inquire at a reputable transmission shop before dumping lube into it. Like the article says "Gear oil is inexpensive, transmissions are not." Keep us posted.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 11-24-2006, 01:06 PM
As it appears to be from a 83 5.0 Mustang this would make it a NWC trans. Has anyone got the manufacturers specifications / recommendations for the trans oil in this vehicle?
I used this site for identification http://www.5speeds.com/t5/
Thanks
Dan
Old 12-12-2006, 07:10 PM
Anyone have the 83 Mustang recommendation - please
Would it destroy my trans if it should have gear oil and I use ATF ? I can understand gear oil being to thick for a trans that needs ATF, so is it just as bad using ATF when it needs gear oil?
Daniel
Old 12-12-2006, 08:39 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Is the trans a "stock" T-5 ie: not been rebuilt or upgraded to the WC "Z"?
If upgraded you can use either ATF or 70w Red Climbing Gear oil, if it is stock they generally reccommend ATF although some of Ford's SVO's were a bit unique in their drivetrain components.
Being from NZ are there any Ford dealers that have a competent parts/service dept. close(rather lacking close to where I live )usually they can look up the information if they have the parts number and or vechicle it came out of .
On doing a search of several Mustang forums it seems the V-8 SVO Mustang for '83 used a pretty stock T-5 trans. These transmissions used ATF...'84 and later began to see more of what would become the "WC" and were beefier for the V-8's. hope this helps
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 12-13-2006, 07:38 AM
Jimi G's Avatar
We rebuild T5's on a daily basis, Z rated, WC, NWC and all in between. The only fluid we will ever put in any T5 is Amsoil Synthetic ATF. jimig@standardtransmission.com
Old 12-13-2006, 01:06 PM
Thanks Jimi G, that was the confirmation I needed.
Old 12-13-2006, 01:10 PM
Jimi G's Avatar
Not A problem, let me know if you need anything else. jimig@standardtransmission.com
