SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 01-21-2007, 06:34 PM
351-EM's Avatar
Cobra Make, Engine: Everrett-Morrison Cobra, 427W T-5 Z tranny
Default Slave Cylinder set-up for SBF
I am trying to find ideas and/or pictures to help me set up my slave cylinder assembly on my Everett-Morrison. I am using a super duty T-5 with my 427W stroker and a wilwood slave cylinder, but it keeps kicking my butt during the set-up. Any ideas and pictures you guys can provide would be greatly appreciated. I have been away from my car for a while in the Navy and would like to work out the last issues to get her done.
Thanks,
Chris
Old 01-21-2007, 07:53 PM
Tommy's Avatar
Sorry, no pictures but here's what I did. My E-M has a Richmond transmission and a pusher type slave cylinder. While laying under the car, I could see that the slave cylinder needed to be mounted about even with the front face of the scatter shield. As my slave cylinder had mounting holes perpendicular to the length of the cylinder, I realized an L-shaped bracket mounted to the scatter shield would work. I fabricated a bracket from a short lenth of angle iron with braces welded at each end to reduce flexing. I held the bracket in place and marked the locations for holes for mounting the bracket to the scatter shield. I also marked the bracket for holes for the slave cylinder and then drilled the holes. It works fine.
Tommy
Previously owned EM Cobra
Old 01-22-2007, 04:42 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Chris;
When I set mine up (351 Dart, T600, McLeod street twin and scatter shield) my problem was the clutch arm hitting the frame no matter where I mounted my slave. After I carved the arm down to the point where it fit the frame but the piston end had nowhere to rest I finally gave up, took Unique's advice and bought a Mcleod hydraulic TOB from Standard Trans. Problem solved. Luckily I had the body off at the time or I'd still be bangin' away at it.
Bill Stradtner
Old 01-22-2007, 04:44 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
It's not an E-M, and it's not small block motor, but it is a small block fork with a drivers side pivot, a Willwood slave pulling to the rear, mounted to the frame with a single bolt. The square tube is only a spacer, and the nut holding the bolt is inside the footwell.
From the bottom looking up
Old 01-23-2007, 10:38 PM
Cobra Make, Engine: HI-TECH 289 FIA
These brackets and kits are widely available. Most any Mustang parts house. Try http://www.autoworksracing.com/
fiaroadster
Old 01-24-2007, 07:30 AM
Burgs's Avatar
Rick, How is that setup working for you?
Old 01-24-2007, 10:00 AM
For now I have a top loader,I'll let you know in a few months.
fiaroadster
Old 01-27-2007, 08:15 PM
Cobra Make, Engine: early Contemporary Cobra (1005), 67 Shelby GT350 with Inline carb on a Boss 302
Default Clutch Slave cylinder bracket
Take a look at my gallery for a photo of the set-up I made for mounting the clutch slave cylinder in a Contemporary frame. The cylinder is a CNC with the push rod shortened. The FE fork was ground down to clear the frame and a new spring mount hole drilled. The right angle bracket uses one bellhousing bolt to mount and the dowel to keep it located. The Lakewood scattershield mounts the clutch fork at a lower point, so either you have to raise the pivot up or cut down the arm. I don't like notching the 4" frame tube, it's strength is in it's round wall. Hydraulic throw-out bearings require pulling the transmission to service. My 2 cents worth,
Old 02-10-2007, 07:14 PM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
This is a Wilwood pull type slave, using a T5Z, and a SBF. The slave connects to a bracket that's bolted to an Energy Suspension motor mount. The shaft rides in the original hole in the bell housing and I used the plastic end of an old Mustang clutch cable as a bushing. The piece of stainless all thread and coupling nut I sourced from www.mcmaster.com. The slave works very well with a 1" Wilwood master cylinder.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
Old 05-11-2007, 02:25 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Rick 427 Cobra:
The picture of the T5 mounted slave is exactly what I have, but after about a half hour of driving it feels like I need more clutch disengagement to shift into 1st gear at a light. It feels like the tranny gears are still spinning.
How much travel of the pivot arm is needed to typically disengage a clutch properly?
I have a Ford Racing 10.5" clutch and a 3/4" Wilwood master cylinder.
Any help would be appreciated.
Thanks,
Jim
OhioCobraClub.com
Old 05-11-2007, 04:22 PM
I had the same problem. A 1" wilwood master cured it.
