SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 07-18-2007, 09:52 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Default T-5 Serial Number location?
I was swapping out my transmission recently (with the help of a friend who used to own a transmission shop many years ago--how lucky can you get) and I was trying to find the serial number. I could find a cast 13-52-xx-xx number on the left side of the forward case, which we both took to be some kind of part number. We also saw a number etched into one of the flanges on the new trans, and a similar number stamped into a flange on the old trans. We think those etched or stamped numbers are the serial numbers. Anyone know otherwise?
As usual, all help appreciated.
Bill
"If your work speaks for itself, don't interrupt"
Old 07-18-2007, 12:12 PM
Jimi G's Avatar
Post the numbers you found and I should be able to i.d. it for you. There is usally a tag on the transmission with 13-52-xxx-xxx on it, if that is there post that number as well. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 07-18-2007, 12:30 PM
Sledge's Avatar
Thanks, will do when I get home. No tag anywhere with the 13-52 etc. numbers on it.
Bill
Old 07-19-2007, 09:18 AM
Sledge's Avatar
Jimi G:
I'm just trying to verify if these numbers could be or are serial numbers:
TF152397 and LF172667.
The TF number is on the T5 I just put on, and the LF number is on the T5 I just took off.
Thanks
Bill
Bill
