Old 09-14-2007, 04:22 AM
WildBill3's Avatar
Question tko600 problems 2nd to 3rd shifts.
we posted this on the temporary site but i cant find it so here we go again.our 2nd to 3rd gear shift is nearly imposible while hard on the gas ,i looked at the other treads and we havent broke it in on automatic tranni fluid, im not sure if we should drain and go back and do that??we didnt put in the gm mtl but we did buy an equivelent made by pensoil i think.It doesnt seem to work if i let the tranny do all the work as some have suggested to just finger tip it into gear,lord knows iv tryd. this tranni only has about 5 hours of race time on it being drags20 runs or so 5 or 6 autox,s and a sat road corse sesion at Runngun,any ideas??? thanks Bill o yea all the other shifts are great no problems..
Old 09-14-2007, 05:38 AM
Default Not good Bill
WillBill3 It could be a rail or fork problem. Sound like the 1-2 rod is not going back to center and will not let the 3-4 rod move until it is centered. You have a couple of weeks, Pull trans and find a certified T-56 trans shop. There are 2 other ideas also. Send to G-Force and let them install the updated kit and blue print the guts,there are a couple of other companys that do the same updates. I have had very good luck with G-Force.Rick Lake
Old 09-14-2007, 05:57 AM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Aren't the TKO's very sensetive to the fluids used?? I was told to only use the recommended fluid or hard shifting could result...
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
Old 09-14-2007, 06:16 AM
Jimi G's Avatar
I would recommend changing the fluid to Amsoil sycromesh, it holds 5.28 pints. Also you might try switching to a aftermarket shift top, they can improve the 2-3 shifts by shortening the overall throw. What RPM's are you turning during your 2-3 shifts? jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 09-14-2007, 06:51 AM
TKO 600 already has the short throw shifter in it.
BDR 559
SBF 410
HP= Enough!!
Old 09-14-2007, 08:42 AM
Jimi G's Avatar
True the original shifter is made by Hurst but when shifted fast it can still cause a missed shift. jimig@standardtransmission.com
Old 09-14-2007, 09:03 AM
WildBill3's Avatar
it has a Pro 5.0 shifter and pretty high revs 6000 +.Funny you should mention rpm if your just cruising around it goes in 3rd if im off the gas . im shifting at high rpms in 1to 2nd ,I also seen i can go 2nd to 4th and only drop about a half sec off my qaurter time by not using 3rd,but if im going to track the car in a couple of weeks @runngun i really need that 3rd gear on corse
Old 09-14-2007, 10:38 AM
Cobra Make, Engine: SPF MKIII, Rousch 402
Bill.
I have had the same problem with my car since inception, at about the same RPM range as you, I was told the quick shift is the problem and told pretty much the same as you .....fingertip the shift, that is hard to do when every other gear lets me bang it right into gear. I tried the fingertip (so to speak) shift and it works. All I really do now is shift more carefully, if that makes sense. I just let the shifter do the work and dont push it towards fifth at all, actually have to purposely guide it to the left. As stupid as this sounds it has helped.
I know alot of folks witht he same prob even after the blueprint process. I am not real happy with having to shift it this way but I dont race enough to be bugged that much.
One last suggestion to me is to use Ultra shift or maybe it is slick shift available at performanceunlimited.com. I have yet to try this but I think I will give it a go. My 2 cents RYan
"It gets better than this"
Old 09-14-2007, 11:40 AM
Jimi G's Avatar
The problem you are having is because of the rpm's you are shifting at, TKO's do not like to be shifted above 6000 rpm's.
Old 09-14-2007, 02:18 PM
WildBill3's Avatar
wow and all this time i thought i was getting the best tranni out ther for high performance use.I should just go to a jerico i think if i really want to drive this hard ,what a bite. O well thanks for the sound ansers thats why I love going here,and thanks much for getting the site back up Brent U R THE MAN!!!!sin WB3
Old 09-14-2007, 02:54 PM
Jimi G's Avatar
There are some things you can do to the TKO internally to make them shift at a high RPM. jimig@standardtransmission.com
