SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 09-26-2007, 08:52 AM
double ugly's Avatar
Default Tranny oil quantity
I have a TR 3550 and will purchase two quarts of the GM synchromesh fluid. This will be more than adequate, won't it?
Thanks, John
double ugly
Old 09-26-2007, 09:25 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Fill it until it overflows. I've had good luck with Redline MTL. www.redlineoil.com
Bob
Old 09-26-2007, 09:30 AM
Jimi G's Avatar
Actually the TR3550, along with the TKO's holds 5.28 pints which equals almost 3 qts. as stated above fill it until it comes out the fill hole. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 09-26-2007, 09:42 AM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Jimi G,
Don't mean to hijack this thread but I saw your avatar & have a question you can probably answer.
I have a 1984 T-5 in my Cobra, what do I use for tranny fluid? Some people say ATF & some tell me 70 wt. oil.
Any advice?
Thanks,
Randy
Juggernaut
Old 09-26-2007, 09:45 AM
I was wondering if two quarts would be enough. I'll buy three.
Thanks.
John
double ugly
Old 09-26-2007, 09:56 AM
Jimi G's Avatar
Thanks.
John
John I would also recommend useing Amsoil sycromesh fluid it seems to work the best. jimig@standardtransmission.com
Old 09-26-2007, 10:00 AM
Jimi G's Avatar
Originally Posted by Juggernaut
Jimi G,
Any advice?
Thanks,
Randy
Randy use the ATF, 70 wt. will cause the transmission to fail alot sooner then intended, the ATF fluid works better with the sycros internally in your transmission. If you have anymore questions on your transmission just let me know. jimig@standardtransmission.com
Old 09-26-2007, 10:31 AM
Juggernaut's Avatar
Jimi G,
Thanks for letting me know. I kept getting different answers from different people & I didn't know which way to go.
Thanks again,
Randy
Juggernaut
Old 09-26-2007, 11:28 AM
Jimi G's Avatar
Jimi G,
Thanks again,
Randy
No problem Randy, there are alot of people still stuck in that old school mentality of useing 90 wt oil in there trannies but the new ones just won't take it. jimig@standardtransmission.com
Old 09-26-2007, 12:31 PM
HI Cobra's Avatar
Tremec has a good web site where you can download all kinds of info on
their transmissions including shop manuals, specs, etc. I was able to get
plenty of info on my T-5z, including quantity and type of fluid - Dexron III
ATF, slightly less than 3 quarts before it starts running out - as others have
stated, for mine too.
Flip
