SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 10-08-2007, 07:57 AM
Default Looking for a 5-speed
Hello,
My Cobra currently has a Borg Warner T-10 behind a SBC 350. I'm looking to put a 5-speed to get a few MPG on the highway. I've found a variety of transmissions, some from Mustangs and others from various Camaros. The GM versions all say World Class, but the Mustangs apparently were not. Is there any easy way to identify one 5-speed from another? Would any of them bolt up to my existing bellhousing as I really don't want to mess with replacing the slave cylinder and other pieces.
Thanks in advance.
Old 10-08-2007, 08:26 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
TKO 600
Talk to JimiG her on CC.
Old 10-08-2007, 10:21 AM
Jimi G's Avatar
I would recommend the TKO600 it will take all the power you can throw at it and it will bolt right up in place of your T10. It will come with a 26 spline input so you would possibly have to change your clutch disk to a 26 spline disk. The only other difference you will run into is that they are an internal linkage transmission unlike your T10 which is an external linkage transmission. Basically your shifter is offset 2" towards the drivers side and the TKO will come up in the center. There are off set shift tops or you can just open up the hole in your tunnel a little bit. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 10-10-2007, 06:37 PM
Cobra Make, Engine: CSX4000, 427
To get optimal crusing mpg, you should be using a vacuum advanced distributor.
What rear end gearing are you running?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 10-10-2007, 06:58 PM
Using a vacuum advance already. Rear gears are 3.31 supposedly. I never really jacked it up and checked it out.
